Kyocera TA 4551ci - dots on printing
  • max299x
    • Dec 2022
    • 6
    Hello everybody,
    I have a Kyocera TA 4551ci which prints black and yellow dots on the sheet. I tried taking the drum apart and cleaning everything up but the result didn't change. Do you think the two color drum unit needs to be replaced?
    I attach a copy of a blank sheet.
  • toddanderson
    • Dec 2005
    • 234
    Re: Kyocera TA 4551ci - dots on printing
    Replace the charge rollers
    Originally posted by max299x
    Hello everybody,
      Agree with Todd. To be sure, you need to measure between the dots. Your service manual has a chart that will tell you which part is the culprit.
        • 22979
        You'll get 37.5mm intervals for the primary charge rollers. Once it starts doing this, it's pointless to clean the charge rollers.
        • max299x
          • Dec 2022
          • 6
          Thanks for your help
