U917 error
    • 16463
    U917 error
    I'm trying to import the address book from a 3051ci to a 3552ci and I'm getting the following error: E4008 - Invalid File Header.
    I'm able to import the data successfully to another 3051ci but not to the newer model.
    Anyone?
  • PrintWhisperer
    • Feb 2018
    • 473
    Re: U917 error
    Hit the download page for the latest model you are using (or 3/4 series) and get the SETUP TOOL.
    You will use it to import the old 917 file(s), select the model to convert the file(s) to, and it will modify the file for the newer device.
    "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
      • 16463
      Re: U917 error
      I'm guessing that the SETUP TOOL is only available on the dealer portal? Unfortunately, I don't have access. Can anyone send it to me if it's not too much trouble?
        • 23010
        Re: U917 error
        Make sure that you're getting the most recent revision of the Setup Tool. As new models come out, the tool must be repeatedly revised. Each model group has different encryption.
        There was a time, when the backup file was in readable text ... not since the FalconIII. =^..^=
          • 16463
          Re: U917 error
          Much appreciated, cat.
            • 16463
            Re: U917 error
            We have success. I was reading another thread on using the Setup Tool and it sounded kinda complicated but I found it to be pretty straight-forward. But I must mention that I purchased the Setup Tool from copier tech and the included instructions were great. All I did was follow each step. Easy Peasy.
            This is new to me and it doesn't take much to get me excited. I have a new toy.
            Thanks to everyone for your help.
              • 23010
              Re: U917 error
              Congratulations on your success!
              The biggest problem with the setup tool, is trying to use an obsolete version on models that were not yet made when the tool was written. =^..^=
              • tmaged
                Owner/Service Manager
                • Oct 2008
                • 1898
                Re: U917 error
                The setup tool has options for other things, but the only thing that works being converted is Address Book, One Touch Keys and Job Accounting.
                Hope that helps !
                -Tony
                www.dtios.com
                Become a fan on Facebook
                • Stooey1871
                  • Aug 2022
                  • 17
                  Re: U917 error
                  'Net Viewer' is always my go to program...
                  I had a look for the setup tool? Doesnt seem to be available on the AU portal?
                  • craigster
                    • Apr 2016
                    • 201
                    Re: U917 error
                    I quit using 917 and just use KM Netviewer much more reliable and no setup tool required
                    • darry1322
                      • Oct 2010
                      • 817
                      Re: U917 error
                      I've been using the setup tool by remotely pulling the 917 data through kfs and putting it on the new machine so it's all done before going to the customer site.
                      • ntbann
                        • Jan 2012
                        • 631
                        Re: U917 error
                        The only issue with this method is you have to call the customer to hit ok on the machine display.
                        • rockstarky
                          • Oct 2023
                          • 2
                          Re: U917 error
                          With using NetViewer / Net Manager is there a way to move settings from one device to another without both machines being at the same location?
                          • Samanator
                            • Sep 2017
                            • 579
                            Re: U917 error
                            Yes. But to me it's a bit of a pain. Much easier to use Net Viewer with both machines at the same location.
                            I will use the Setup Tool when I have to, but the most reliable and quickest for me is Net Viewer.
                            Also, if the customer is using Job Accounting, Net Viewer is the best way I found moving that data from one machine to another.
                            • darry1322
                              • Oct 2010
                              • 817
                              Re: U917 error
                              Does Net Viewer also copy over the current totals for each Job Accounting user? I know 917 will copy over the user and code info but not the current totals for each user.
