Taskalpha 4501 copies getting darker while printing
  • Doug James
    • Jan 2012
    • 935
    [CQ] Taskalpha 4501 copies getting darker while printing
    Hello, This copier is kicking my tail....The copies and prints are getting darker as they come out. I have put a new drum and developer in it. Reset to factory settings. Not sure where to go from here Thought about re-installing firmware but kinda thinking a HVPS issue. Any thoughts will be very helpful.. THANKS Pis Attached
  • copiertec
    • Jan 2016
    • 2187
    Re: Taskalpha 4501 copies getting darker while printing
    Have you removed the transfer unit and cleaned all the electrical contacts? Those build up with toner dust and can cause voltage issues.
      Those dark spots are repetitive. What's the distance between?
        • 22979
        Have you cleaned the developer unit air ducts and filters on the rear machine frame? When there is no airflow, you'll get clouds of loose toner not recovered by the developer unit. =^..^=
        • tmaged
          Owner/Service Manager
          • 1863
          I would think it's DV unit related. You can see the toner around the image areas which is usually a bias issue. Either counts didn't get cleared so the voltage is off, or something along those lines.
          Hope that helps !
          -Tony
          www.dtios.com
          Become a fan on Facebook
          • Doug James
            • Jan 2012
            • 935
            Thanks, I will give that a shot... Appreciate that !!
            • Doug James
              • Jan 2012
              • 935
              Thinking about the length of the mag roller It LEF It could be the charge, I will have to check.Thanks So Much !!
              • Doug James
                • Jan 2012
                • 935
                I actually be that. It is in a horribly dirty environment (Right next to a Super Fund Site where toxic materials are permanently stored)
                • Doug James
                  • Jan 2012
                  • 935
                  Thanks so much I will give that a shot !! I'm thinking developer issue also ... THANKS !!!
                  • sparkycivic
                    • Apr 2017
                    • 348
                    Those repetitive marks really look like charge roller marks to me, which DO tend to get worse with heat/job length. When you replaced the drum, did it have a new charge roller in it, or did you bring the existing charge roller over?
                    A charge roller with "bumps" cannot be re-used. The underlying steel shaft is rusted.
                    • Doug James
                      • Jan 2012
                      • 935
                      Strangely enough none of these suggestions worked. Going to bring the copier back to my shop and I will post the solution. (Kinda hoping a loaner copier will have the same issue pointing to an outside power issue lol)
                      • copiertec
                        • Jan 2016
                        • 2187
                        Have you tested the AC voltage at the wall? Seems easier to test that then to swap out the entire copier.
                        • Doug James
                          • Jan 2012
                          • 935
                          Humbly saying lol... Turned out to be the developer housing. I get parts harvested from low meter machines and I put 2 bad ones in the machine to troubleshoot. I am thinkin the developer ages out. Oh well it's the risk I take. I usually don't fall flat on my face though. THANKS FOR ALL THE HELP!!! It is appreciated more than you know !!!
                            • 22979
                            Congratulations on your success! Thanks for posting back. =^..^=
                            • tmaged
                              • 1863
                              Hope that helps !
                              -Tony
                              www.dtios.com
