Kyrocera M3550IDN
  • bkramer
    • May 2022
    • 3
    Kyrocera M3550IDN
    Machine does not lift tray. Errors out 1010 code. The motor does not even turn on. Is it the drive motor 302LV94251? or a board? The gear on the tray is fine
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1888
    Re: Kyrocera M3550IDN
    Replace the cassette with the spring loaded tray from the lower speed version of that series.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • JR2ALTA
      • Feb 2010
      • 2033
      Take this advice. Get a CT3100 302MS93018 There are detailed posts about this problem on this website.
      Tell the customer it's been upgraded.
      • bkramer
        • May 2022
        • 3
        ... I will try that. When I remove the tray and actuate it the motor does not try to lift at all.
        • subaro
          • Oct 2010
          • 1274
          The problem is most likely the bottom frame that holds the tray lift motor. The rib, that holds the gear which the motor dirves, cracks and therefore does not lift. There is a bulletin on this, with a modified replacement part. I have done a few of these and it is not difficult to do. Just pay attention to the fuser drive gear and the spring that it works with, the orientation of it.
          • bkramer
            • May 2022
            • 3
            Do you happen to have that part number and bulletin?
            • subaro
              • Oct 2010
              • 1274
              New replacement part number.
              302LV02040
              GUIDE CASSETTE R
              The bulletin has the whole description of the error the fix, parts and diagrams..
              • ntbann
                • Jan 2012
                • 628
                A CT-3100 is way easier.
                  • 23009
                  302LV02040
                  GUIDE CASSETTE R
                  I will confirm that this is the fix, and that it's no small task to replace the right cassette rail. It's the post that supports the gear that fails most often, and it's molded into the right cassette rail. Either bring the machine into the office, or move the machine to a spacious room so you can remove a lot of parts. =^..^=
                  • sparkycivic
                    • Apr 2017
                    • 348
                    Also sometimes need to block the sensor above the feed roller assy to make sure the code C1010 stays away.
