TASKalfa 4052ci error 441
  • taskalfa
    • Jun 2011
    • 97
    [Error Code] TASKalfa 4052ci error 441
    Hi all, not sure if anyone can help, I have a 4052ci which constantly throws a system error 441 every day when sitting idle , user has to power it off and on and copier working again. Also noticed it throws a few calibration errors 7611 7614 7620, I have tried so far the main pcb, hard drive , 021 024 resets, problem still persist , copier has a 1000 sheet finisher with hole punch unit
    • 22959
    Re: TASKalfa 4052ci error 441
    Can you see any patches on the transfer belt when it errors out (after attempting calibration)? There are lots of possibilities (in this order):
    Some of the color patches are missing (specifically check black & yellow based on the codes C7611, C7614, C7620): maybe drum, maybe dev, maybe HVT, maybe laser
    Transfer belt issue: not rotating, torn belt, displaced primary transfer roller
    ID sensor issue: shutter doesn't open, pile of toner on the ID sensor, defective ID sensor
    I can narrow it down a little if I know which patches are present, and which are not. =^..^=
    • taskalfa
      • Jun 2011
      • 97
      Unfortunately we are never there when the problem occurs, customer just cycles copier and away they go again, strange thing is that this copier was working without a problem, it was decommissioned from previous customer and returned back to us , after sitting for about 6 months we sold it to another customer and this is when the 441 errors starting appearing, maybe when the copier was transported to new site it was bumped around. I have included a screen shot of the errors, its more so the 441 error thats concerning me, according to service manual F3AX F3BX F3CX F3DX F3EX F3FX F40X F41X F42X F43X F44X F45X
      "Abnormality detecting in the Entity Management Department"
      1. Initialize HDD and perform an operation check.
      (FULL of U024) *
      2. Carry out U021 Main backup initialization and perform an operation check.
      3. Exchange a Main board and perform an operation check.
      5. Get USBLOG and contact service headquarters.
      * Only HDD standard model
        • 22959
        AH! You mean CF441.
        This is the description from a Wisecore Bulletin:
        Component: CreateScan. Category: ImageProcess. Initialize Error. (the rest reads the same as your entry).
        This description implies to me that the image was not properly processed during image processing. If you were only getting the CF441 I might suspect the CCD. But the additional codes are pointing to the color calibration happening at the engine board. And the scanned image (for a copy) is also directly processed on the engine board.
        I think the engine PWB makes more sense to me. You may have to do U411 CCD calibrations when changing the engine PWB ... I think I would. Have the test charts available. =^..^=
        • taskalfa
          • Jun 2011
          • 97
          • copiertec
            • Jan 2016
            • 2186
            When you moved the machine did you remove all toners and developing units? We always make sure to do this with all of our copiers, we would have issues with our Sharp copiers after moves and found excess toner dropping in the developing units after the move and it would cause error codes ad CQ issues sometimes. I know one time we had a TA-5501i after a move start to act up, we moved it with out removing the toner and developing unit and cq issues until we replaced the developing unit. We took the developing unit back to the shop, vacuumed it out, installed it in to another copier and it worked great.
            • KYO_OEM
              • Aug 2011
              • 695
              regarding C76xx codes, check the U465/ Stress values.
              Front and rear value must be >90.
              If always 90 for front or rear, the surface from the belt is damaged/ overaged and new belt needed.
              @BC
              if the shutter for the ID sensors will not work, you get C7601 for the front sensor and/ or C7602 for the rear sensor.
                • 22959
                Thanks, KYO. =^..^=
                • Trevor376
                  • Jul 2017
                  • 14
                  Ihave been seeing the f441 error on multiple machines 3511, 9002, 4052, 4002. I am curious did you have this machine on KFS. I am wondering if the machine is not waking up properly for communications with KFS. I know for a fact that the 9002 machine I have doing it the customer will not be using it and it will go to this error. we have tride replacing hard drive. 21, 24. Next step I think is going to be Main board or I am thinking of removing it from KFS and see if the errors stop
                  • taskalfa
                    • Jun 2011
                    • 97
                    • kuby
                      • Oct 2007
                      • 1386
                      Have to tried turning on the 'Auto Error Clear', that has resolved some errors we were having.
                      • Dark Helmet
                        • May 2009
                        • 835
                        Had this error code today on a 6003. Customers power went on and off numerous times quickly before it finally kicked out for 6 hours.
                        It was strange, machine was offline (maybe power was still out but they placed the call) when we checked KFS and the next day it was online again but they couldn't print. Copy was fine. Had the user hard reset the machine, unplug, hit soft power switch 3 times and plug back in and away it went.
                        • dalewb74
                          • Feb 2018
                          • 1125
                          is it plugged into a good surge protector designed for copiers? or is it on a cheap $5 surge protector? is there other stuff on that same breaker that could be overloading it... i would lean towards the power as well. especially since you moved from one location to another and now it works.
                          • MadCityCopy
                            ieeeee
                            • Oct 2010
                            • 58
                            Bumping this,
                            I have a older 3511i that the client changed to Starlink internet and this code now comes up every morning. The F441. This machine was working fine on the previous internet. I think its just a coincidence. Strange. Just wanted to add this info out there. I am waiting to go onsite to check it out by my KFS has the logs.
                            • tmaged
                              Owner/Service Manager
                              • 1862
                              I've posted on this previously. Disabling IPv6 on the MFP will take care of it.
                              Hope that helps !
                              -Tony
                              www.dtios.com
                              Become a fan on Facebook
