TA 5052ci PQ
  • Service@PRT
    • Oct 2016
    • 181
    TA 5052ci PQ
    Just want know whats the cause? Suddenly become like this. Before going to the client? Counter is 250k. Just to prepare which thing to bring. Im not familiar much with kyocera? Any advise will highly appreciated
    Sent from my YAL-L21 using Tapatalk
    Every day of life is a learning process...
    Just make sure you are open in all aspects of comments.
  • copier tech
    • 8169
    Re: TA 5052ci PQ
    If you have a set of drums I'd take these with you.
    When you arrive on site use sim code U89 & run a sample set this will give print out a test of colour test prints to help diagnose.
    • Service@PRT
      • Oct 2016
      • 181
      Re: TA 5052ci PQ
      Seems need 4 drums [emoji43][emoji43][emoji43]
        • 16406
        Re: TA 5052ci PQ
        Are you using OEM toner? I would try replacing all the PCR's and running U464 and U410.
        • KYO_OEM
          • Aug 2011
          • 720
          Re: TA 5052ci PQ
          drum bk overaged, produced 2016-08, life count 255418 pages/ expected 200K/ 150.000m(U120)
          drums CMY, produced 2016-08, life count 159758 pages/ expected 200K/ 150.000m(U120)
          belt produced 2021-04, counter unknown, U465/ "Stress" also unknown
          I agree with Billy regarding U464 and U410 after exchange from dk units.
            • 16406
            Re: TA 5052ci PQ
            Just so I'm clear, the drum for the 5052ci is rated at 600K? I understand that you're saying its overaged. Just wanted to be clear on the rated page count for the drum.
            • KYO_OEM
              • Aug 2011
              • 720
              Re: TA 5052ci PQ
              you are right Billy!!
              mistake from my side!
              mistakenly 25ppm instead of 50ppm readed
              Now let`s try other kind of analysing:
              50ppm system from 2016-08 had run 255k only.
              2016/08-2022/12=76month
              255k/76month=3355 pages per month
              3355pages/ month/ 22days=152 pages/day
              In this case i think the dv units are the problem.
              High stress for the carrier.
              DV refresh, U464 and U410 maybe can be helpfull before exchange
              • KYO_OEM
                • Aug 2011
                • 720
                Re: TA 5052ci PQ
                you learned something about the CASS system
                I think in this case too much broken carrier was going out against new carrier was coming in by adding toner.
                  • 16406
                  Re: TA 5052ci PQ
                  I never thought about it in those exact terms but it makes sense. When this machine has low copy/print count year after year, the carrier becomes worn and more is going out than coming in. Makes perfect sense.
                  • Service@PRT
                    • Oct 2016
                    • 181
                    Re: TA 5052ci PQ
                    Yes it is oem toners
                    • Service@PRT
                      • Oct 2016
                      • 181
                      Re: TA 5052ci PQ
                      Thanks. Will go there now to try. Really appreciate billy and kyo!
                      • PrintWhisperer
                        • Feb 2018
                        • 472
                        Re: TA 5052ci PQ
                        This is why, when it comes to toner, it's "Use it or lose it" because if it's not put on pages, it'll eventually have to be flushed out by running several developer refreshes. This is to eject overcharged toner from stirring 'tribo-electric effect' during driving. Kyocera started the system of camming the TX belt and stopping CMY dv drive during K only mode all to help alleviate unnecessary DV driving.
                        So those low-coverage rates in tiered billing will bite you in the ass a bit (with toner inclusive contracts) if the volumes are not high.
                        It even happens on the opposite side, though more rarely. If you run extremely high toner coverage then the carrier builds up faster than the developer discharges waste. Imagine spiral stripe carrier (auger pattern) mashed into the sleeve roller and buffing the drum.
                        Both conditions are because the dv waste auger is tied to the dv drive time and not based on the rate at which toner-carrier mix is added
                        "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
                        • Service@PRT
                          • Oct 2016
                          • 181
                          Re: TA 5052ci PQ
                          Replaced 4 (Geniune) PCRs.. still same... Now waiting for the developers to come...
                          Thanks all for the inputs.. hope to fix the problem.
