TA 3252 (Intermittent) Stalls while scanning to File pdf etc
  • Doug James
    • Jan 2012
    • 935
    [Misc] TA 3252 (Intermittent) Stalls while scanning to File pdf etc
    The customer will pick the scan destination then put the papers in the ADF she hits start. The sheet will feed in a few inches then the copier will stop to the point that she will have to turn the copier off and on again. I believe she is scanning to email and not a folder. It does not do it it the middle of a job. I cannot re-create the problem. Works for me every time when I am there... We are at the point of having the Kyocera helpdesk check what they could but at this point they can't log into the network because of security issues. We are working that out so they can check the network. (The IT guy has the network very locked down) Any Help is VERY appreciated !!!
  • copiertec
    • Jan 2016
    • 2197
    Re: TA 3252 (Intermittent) Stalls while scanning to File pdf etc
    If it's happening on scan to email only and scanning to folder with no issues, I would think it's an IT issue and consult with their IT dept. IMO scan to email is not as reliable as scan to smb. Make sure your firmware is up to date, port, dns, and smtp settings are correct along with reply address.
    • Doug James
      • Jan 2012
      • 935
      Going to try to have Kyocera look at it tomorrow. I am trying to get ahead of things and wondering what hardware to install if needed or if an IT problem is what to concentrate on. Not knowing the IT side sure slows me down here... lol I appreciate your response and will show to the IT guy I am meeting with tomorrow. THANKS !!
        • 16354
        There's not much to go off of. Are they using a gmail account or what? Maybe do a continuous ping to the router to make sure the connection is good. You can even ping the mail server. Exp.: ping smtp.gmail.com -t
        You can also do a tracert to see how many hops to the mail server and if the route may be broken. Example: tracert smpt.gmail.com
        It could be anything at this point. Bad port on the switch. Bad network cable. Or the problem may lie on the other side of the router. Good luck.
        • KYO_OEM
          • Aug 2011
          • 711
          system will not ask for restart without showing any kind of error code on the screen.
          Please ask the customer to check the screen in case of error.
          When i am right, lower left corner you will see the error code
          Also check event log for c-calls at first.
          • what_moustache
            • Jan 2015
            • 14
            I agree that it definitely sounds like a network issue, however, I also just had very similar symptoms on a 4002i that were caused by a crack in the document processor frame (more or less). If it happens at all on any other use of the DP (copying, scan to USB, etc) and it's a DP-7100, it could be that. QA 2ND-0131 (J059) has the details, but I got c9180 (DP shift motor) errors and j0100 (paper jam caused by firmware factors), then found shattered screw posts when the hotline had me replace the DP PWB. It took several emails to our rep to find that QA, even the hotline tech didn't know about it.
            • Samanator
              • Sep 2017
              • 576
              I think that scanning to USB memory is a troubleshooting tool that is often overlooked. I can check a lot on an ADF with U0243 and U244. But for me, nothing beats running originals through the ADF for testing. And the best way I have found is just scanning to USB memory. It kind of like when I make a copy off the glass and check it against a copy made thru the ADF or print job. Isolating where the problem may be, that is, finding out where there is no problem.
              • Lunatech
                • Oct 2012
                • 202
                I had a case a few months ago that sounds similar to this (maybe). It is a 3252 with a DP-7110. When scanning a 2 sided document, copy, folder or usb, it would sometimes stall out and hang on a screen that read processing or scanning or something like that. It would not get past that screen without turning it off and back on. Never asked for a reboot or logged anything in the event log either.
                After cleaning everything I replaced the CID, HDD, main boards in the print engine and DP to no avail. I replaced the top door of the DP and cured it. As it turns out the white roller in the top door was the culprit. I put a new one in the original top cover and has been fine since. The white roller that was causing all the problem did not look dirty or defective in any way, it just did not work.
                FWIW, I hope this helps.
                • Lunatech
                  • Oct 2012
                  • 202
                  Correct me if I'm wrong.
                  If it is caused by counterfeit prevention it will make you restart and not give a code or log anything in the event log, correct?
                  • PrintWhisperer
                    • Feb 2018
                    • 468
                    Originally posted by Doug James
                    The customer will pick the scan destination then put the papers in the ADF she hits start. The sheet will feed in a few inches then the copier will stop to the point that she will have to turn the copier off and on again...
                    If it is a Dual Scan DP then swap out/reseat the DPIF PWB. It has 500MB memory for DP scan data which may have a failure.
                    "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
