Vertical lines CS6003i
  • Copier Mechanic
    • Mar 2023
    • 89
    What do you all think? I think it's the developer. I forgot to get the count U158 but this machine has 1.7 millions count already maintenance count #A has 454K count. See notes on status page.
    Oh and this machines uses OEM toner which I'm surprised because normally we use cheap toners.
  • sparkycivic
    • Apr 2017
    • 348
    Re: Vertical lines CS6003i
    what condition did you find the developer and charge roller?
    You might also want to inspect along the HV lines toward the PWB's and the HV PWB surfaces and machine frame for dust/toner attracting to static.
    • Copier Mechanic
      • Mar 2023
      • 89
      Developer had no visible void lines when I spun it with my hand and charge roller looked pretty clean and smooth. I should look into the HV lines going to the PWB. I heard toner and dust on PWB can cause some kind of shortages or something.
      • sparkycivic
        • Apr 2017
        • 348
        was any toner leaking out of the developer or drum ?
          • 16416
          U089?
          Generic toner?
          • copykat93
            • Oct 2021
            • 281
            Is it Genuine OEM Kyocera toner? Even if it is... I would sweep out the entire developer unit, use a clean cotton rag & manually wipe and scrub the mag roller & reload OEM toner only with sim... please post you fix... hope this helps
              • 23009
              I suspect that you have a mixture of knock-off toner & genuine toner, and they often do not mix well. If that is the case, running a few hundred heavy fill black images should gradually deplete the knock-off toner from the mix, and gradually improve the image. Typically the starter is not damaged, but it's always possible.
              I had a situation in which my enduser was using the WORST Chinese knock-off toner, and the image quality was horrible. I told them that if they were patient for the quality improvement, they could buy four genuine toners, install them, and keep using the machine. I ended up being called out 6 months later for another issue. The copy quality was nearly perfect. The enduser said that it cleared up over 4 weeks, gradually.
              It sure beats buying four new developing units AND four toners. Patience is the key here to save money. =^..^=
              • Copier Mechanic
                • Mar 2023
                • 89
                U089?
                Generic toner?
                For some reason, it wouldn't let me print U89. This machine uses OEM. Note: it wouldn't let me do a DV refresh
                • Copier Mechanic
                  • Mar 2023
                  • 89
                  Well it had some toner on top of developer housing and drum no visibly leaking just contaminated with toner on outside of housing. I vacuumed it and put it back.
                  • Copier Mechanic
                    • Mar 2023
                    • 89
                    My manager decided to order a new Developer. This machine is using OEM toner. Since this customer is located 80 miles away, My boss prefer to order the whole parts instead of trying to mess with it
                    • Ropariva
                      • 680
                      • Copier Mechanic
                        • Mar 2023
                        • 89
                        I didn't know I could do that! Good to know. Thanks Black Cat, I learned something new from you!!
                        • Step
                          Senior Technician
                          • Sep 2015
                          • 42
                          Another thing you need to check is if the U930 counter was cleared after MK and or drum and Main charge was replaced. Some techs do not clear U930.
                          Many a times this was the cause on background and quality of prints on some of our machines.
                          Sent from my SM-A736B using Tapatalk
                          • tmaged
                            Owner/Service Manager
                            • Oct 2008
                            • 1888
                            What's the maintenance counter life ?
                            Hope that helps !
                            -Tony
                            www.dtios.com
                            Become a fan on Facebook
                            • NCCopierTech
                              • Jul 2023
                              • 10
                              Ask them if they could have possibly put a bottle of waste toner back into the machine. I've seen exactly this when a customer put a full bottle of waste toner in and contaminated the developer.
                              Install new bottle of OEM toner, then run a bunch of sky shots to get the waste tone out of the dev unit. The copy quality will return eventually.
