Vertical lines CS6003i
  • darry1322
    • Oct 2010
    • 817
    #16
    Re: Vertical lines CS6003i
    Originally posted by NCCopierTech
    Ask them if they could have possibly put a bottle of waste toner back into the machine. I've seen exactly this when a customer put a full bottle of waste toner in and contaminated the developer.
    Install new bottle of OEM toner, then run a bunch of sky shots to get the waste tone out of the dev unit. The copy quality will return eventually.
    One sure sign of this is if the toner gauge on the Status Page or on KFS shows no toner info.
    • Copier Mechanic
      • Mar 2023
      • 89
      #17
      That's a possibility that could have happened. I better ask the customer. Thanks!!
        • 22999
        #18
        If this is the case, be sure to install new genuine black toner before running heavy fill images. There's already more than enough contaminated, mixed color waste toner in the system.
        • Ropariva
          • 656
          #19
