KM 5050i Sorter Tray A Problem
  • Bugsy
    • Aug 2025
    I've got a wierd one, the 3000 sheet finisher tray A on a KM5050i copier will drop down about a third of the way and go into c8140 code after the print key is pressed. The upper and lower limit sensors are working and I swapped out the sorter pwb and it still does it. When you go into staple mode the sorter works perfectly, it jogs down as packetts come out of the finisher!
    • 23009
    That's probably what I would have tried too.
    With the weird behavior (it should never have to home out tray A to the bottom), I would reload firmware next. If that doesn't help, the only other logical choice is the MFPs engine controller.
    I don't suppose you have another DF-710 that you can attach for testing purposes? =^..^=
    • Bugsy
      Have a "Manual", have loaded the newest "Firmware".I have 30 years plus in the business This machine was made for Ikon Office Solutions by KM, and recently we were bought by RICOH, so we cannot get tech support through Knet.
        • 23009
        Obviously that signature line is not for you then.
        This is what the manual suggests:
        DF-710 Main Tray Problem. Main tray is not detected in not detected by main tray top limit detection sensor or main tray capacity detection sensor within 20 sec of ascending. Main tray upper limit detection sensor or main tray load detection sensor is not detected as Off within 20 sec of main tray descending. Main tray lower limit detection sensor is not detected as On within 20 sec of main tray descending. Main tray upper limit detection sensor or main tray load detection sensor remain on for 2 sec or more during main tray ascent.
        1) Reseat YC6 @ finisher main PWB & connector for main tray motor, 2) Pinout harnass, 3) Replace main tray upper & lower limit detection switches & main tray load detection sensor, 4) Repl main tray motor, 5) Repl finisher main PWB.
        You must know that this error must be reset in sim 906 Partial Reset, or you wouldn't have gotten this far.
        I'm sticking with the engine controller suggestion. And I'm guessing you don't have another finisher to try on.
          • 23009
          What results do you get from sim 240, Finisher Motor, Tray Motor (MTM)?
          • LNorris
            • Sep 2008
            • 645
            i think this is the one i fought for a bit.
            go into sort mode, see if the fingers drop when sorting (on the main tray). if they dont drop and hold the paper, there is a spring broke on the solenoid that pulls the fingers down. if the fingers dont drop, it errors out.
            the spring is on the backside of the finisher. pull the main tray out and see where the fingers are located. on the back side you should see a solenoid below that end, there should be a spring attached. i have had two of these break lately.
            • Bugsy
              All sort functions are working properly in sim mode . The paper never gets to the sorter! when you hit the print button the A tray drops about a third of the way down and then errors out without ever feeding or printing paper!
                • 23009
                Wow, that is a lot of exclaimation points. So far you've shot down all my suggestions. Good work.
                I'm trying to help you work through this, and I'm doing all the thinking. When you're ready to relax and participate, let me know.
                • russmacman
                  Remembers 900d (redtop)
                  • 19
                  Finisher problem
                  Try this... Look / see if the light and or receiver at the top of the main tray is out of alignment. They must see each other to keep the tray at its highest point. Had one that the light from window triggered the sensor, sorter thought that it had to much paper on tray, went down trying to accept more stock. Hope that helps... Russ
                  • Bugsy
                    Sorter exit Tray
                    LNorris you the Man!!!! It was the broken spring on the exit solonoid. Thanks for the heads up and to all the rest of you for your imputs
                    Bugsy
                    • tech07
                      • Aug 2008
                      • 410
                      Fixed a C8140 today.. It was the small wrap spring that hooks on the rear most finger clamper. It was broken allowing the clampers to jitter slightly messing with the sensor.
                      • brecht2
                        • Feb 2012
                        • 71
                        Re: KM 5050i Sorter Tray A Problem
                        Hello,
                        I have the same problem with a KM5050 with a DF-710.
                        I had multiple times c8140. i restart and can't select "tray A" anymore.
                        Only when i execute U906 i can use it for about 5-10minutes then again c8140...
                        Friday i go again to this client with the required sensors, tray motor and main pwb from another DF-710 (like seen in manual).
                        I don't believe in F/W update because it always worked before without update...
                        Anyone any idea or experience about this issue??
                        Thanks in advance.
                        • darry1322
                          • Oct 2010
                          • 817
                          As an earlier poster said.....check the spring on the solenoid that operates the clamp fingers in the output tray A. These are the fingers that would hold one set in position while the next set is outputted.
                          The spring will break causing a failure in the linkage between solenoid and finger mechanism. If the fingers don't move into the down position, you get a failure code.
                          Firmware updates are a good idea even when not solving an obvious problem.
                          • brecht2
                            • Feb 2012
                            • 71
                            Hello Darry,
                            It was a broken solenoid! Since 3 days no recall!
                            Thanks for the reply.
                            Grts
                            • darry1322
                              • Oct 2010
                              • 817
                              you are welcome.
