Kyocera Wallpaper
  • Exodia-P4
    • Jan 2023
    • 125
    Kyocera Wallpaper
    Hello
    I have a Silly question : How can we change the wallpaper on a 2554ci ? (Not the basic pictures but a wallpaper made by me...).
    I find in the documentation that the picture make less than 4Mo and 800px x 480px (using the maintenance, 224), but on my 2554ci, the key are grey and i cant open them...
    Have you an idea ?
  • CoreyAbels
    • Dec 2014
    • 86
    Re: Kyocera Wallpaper
    Originally posted by Exodia-P4
    Hello
    Have you an idea ?
    It's a very simple process, it must be in the .PNG format, less than 4mb in size, 800x480, and it needs to be saved as menu_background.png in the root of a thumb drive. Once all of that is done, the Home Menu Img button should be available in U224.
      • 16312
      Copy the files to an USB-stick and load the files to the machine using U224. The files are :
      callwin_ext_image.png 180x200pix max 1Mb
      callwin_ext_mes_detail.txt
      callwin_ext_mes_top.txt
      opening_ext_image.png 800x400pix max 1Mb
      Use an application like Irfanview to format your image to 800x400 pixels, .png file format, and named exactly as specified. Use simulation U224 to import the image.
      • Exodia-P4
        • Jan 2023
        • 125
        It dont work...
          • 16312
          It dont work...
          It works. You're not doing something right. Follow the instructions exactly as I posted them.
          • dalewb74
            • Feb 2018
            • 1126
            just keep in mind, once you change it, you can't revert back. i learned that one the hard way. and as mentioned, you have to do it exactly. if not it won't work.
            • tmaged
              Owner/Service Manager
              • 1869
              I'm not really sure what this means ? You can remove or reinstall new splash screens in 224 at any time.
              Hope that helps !
              -Tony
              www.dtios.com
              Become a fan on Facebook
                • 8132
                It dont work...
                Are you trying to change the home screen wallpaper or the boot up screen logo ?
                • Exodia-P4
                  • Jan 2023
                  • 125
                  No I cant... Its all grayed out
                    • 16312
                    I'm starting to understand why it's not working for you.
                    He asked you a question!
                    • dalewb74
                      • Feb 2018
                      • 1126
                      yes you can change it to any new file that you wish. but you can not revert it back to the original factory wallpaper. once you change it the original default is gone.
                      • tmaged
                        • 1869
                        Next time you have a chance, select uninstall and highlight the ones you want to revert back to default.
                        Hope that helps !
                        -Tony
                        www.dtios.com
                        • Exodia-P4
                          • Jan 2023
                          • 125
                            • 8132
                            Try this image let me know if it worked.
                            https://mega.nz/file/ZZsniZKB#uFbBpI...ryqD8gKQS98Pig
