Task 3500i
  • copyman
    Owner / Technician
    • Sep 2005
    • 4708
    Task 3500i
    Customer put crap toner in and now has background. I looked for developer but looks like only the complete dev unit is sold, not just the developer powder? I saw some dev powder but was from China.
    Is buying complete dev unit only option? Would it help to to vac out toner hopper, run sky shots, then add OEM toner?
    I usually work on Kon/Min but hope to keep this customer going until they upgrade end of the year.
    Thanks in advance
  • Ropariva
    • 676
    Re: Task 3500i
    A complete dev unit and OEM owner is the only way on these.
    Sent from my iPad using Tapatalk
      • 30238
      Re: Task 3500i
      Thanks in advance
      You can try it with OEM toner vac all out and run setup mode for Dev unit
        • 23008
        Re: Task 3500i
        Customer put crap toner in and now has background. I looked for developer but looks like only the complete dev unit is sold, not just the developer powder? I saw some dev powder but was from China...
        You're in for the same variety of trouble with the generic developer.
        ... is buying complete dev unit only option? Would it help to to vac out toner hopper, run sky shots, then add OEM toner? ...
        That's what I would try first. It's the lowest cost option. Second choice: the whole developing unit.
