Kyocera M2640idw - clean scan glass message
  • kuby
    • Oct 2007
    • 1409
    Is there a way the turn off this message so it does not come on again? It jut keeps coming up and both scan glasses are clean. Customer would like it turned OFF.
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1888
    Re: Kyocera M2640idw - clean scan glass message
    It doesn't look like it has U326 or any way to do it through the system menu that I can see.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • kuby
      • Oct 2007
      • 1409
      Yea that is what I am thinking also.
      • KYO_OEM
        • Aug 2011
        • 721
        I agree with you all, but in past we have had other small A4 devices with sporadically colored scan stripes...
        In this cases U411 was helpfull for correct adjustment from the scanner.
        Maybe this can be helpfull in your case also.
        • Lunatech
          • Oct 2012
          • 208
          Our typical move when this happens is to thoroughly clean the optics. This usually takes care of it. In the cases that it did not take care of it we wound up replacing the device and I was not able to further troubleshoot it.
          • dalewb74
            • Feb 2018
            • 1155
            did the customer clean it? or did you clean it? did you reboot afterwards? the only ones i have seen that says it, means it actually needs cleaning.
