Will KM3050 drum work in KM4050?
  • copyaction
    • Oct 2007
    • 991
    I know, super old but I still have a customer with a 4050.
    I have a brand new DK715 that says it is for 3050.
    Does anyone know if this will work or what the difference may be?
  • KYO_OEM
    • Aug 2011
    • 721
    Re: Will KM3050 drum work in KM4050?
    I do not think that it will work because beginning of serial number from DK715 is diff to SN from DK716
    First 3 digits are showing type of spare part and internal firmware will not accept other digits/ other spare aprts.
    There would no official FW published by KDC to accept other 3 digits also...
    Finally: you`ll get C7900
      • 23009
      I have a vague recollection of trying, and failing. =^..^=
      • dalewb74
        • Feb 2018
        • 1155
        if you are working on those old dinosaurs. do you not have the part number for each?????
          • 900
          You cant just switch the chip from one to the other
          • copyaction
            • Oct 2007
            • 991
              • 23009
              I seem to recall obvious physical differences between the drums. And the EEPROM chip would not let it work even if you could get it installed. =^..^=
              • kleankopy
                • Feb 2016
                • 115
                Just replace the eprom chip on drum and will work fine. Did it all the time.
                • KYO_OEM
                  • Aug 2011
                  • 721
                  @kleankopy
                  How does each system generate a consistent quality?
                  By adjusting the required voltages to the performance of the individual components, like a drum and MC
                  The counter reading and the drum runtime are stored on the eeprom/ chip
                  Old eeprom in new drum with new unused surface/ new MC logically results in incorrect voltages and thus quality problems.
                  You can change the eeprom, but you will have problems afterwards, because U109 + U110 you can`t change.
                  Maybe no problems immediately, but certainly later.
                  Feel free to do it, but don`t wondering about new problems.
                  • copyaction
                    • Oct 2007
                    • 991
                    Ordered MK716 maintenance kit, thanks for the replies.
                    • Gab
                      • Aug 2015
                      • 671
                      First find if opc drum and blade are the same (You can see if compatible opc drums and blades are the same for these models) . If yes replace in old drum unit opc drum and blade with thise from the new drum unit.
