Kyocera 3553ci smearing on magenta
  • kuby
    • Oct 2007
    • 1383
    Tech is having trouble finding the cause. The firmware is up to date. He cleaned the machine, replaced the drum and developing unit for the magenta and still it smears just on the magenta. Life count 621137.
    OEM toner
    Thanks Guys
  • JR2ALTA
    • Feb 2010
    • 2028
    Re: Kyocera 3553ci smearing on magenta
    OEM toner
    Thanks Guys
    Do you have the U089 single color M printout? I'm interested to see if anything repeats.
      • 22943
      That looks like the developing spacers ... magenta developing roller arcing to the magenta drum. Does it only appear in areas of fill over 65%? Does it look like this (this sample was black, but the same principle)?:
      • Ropariva
        • 636
        OEM toner
        Thanks Guys
        Dev spacer will do that. You sure the developer was replaced with a new complete unit?
        Sent from my iPad using Tapatalk
        • kuby
          • Oct 2007
          • 1383
          Yes both the developing unit and the drum were replaced with new OEM units.
          • JR2ALTA
            • Feb 2010
            • 2028
            Again, do they repeat and at what intervals?
            • kuby
              • Oct 2007
              • 1383
              Have to get the tech to run some test. Get back to you.
              • KYO_OEM
                • Aug 2011
                • 692
                DV + DK are new (visible by SNs) DV -->FR10333xxxxx/ DK--->FR50235xxxxx
                What`s behind U110 and U120?
                Does both points would set to "0" by the system or did he mount the units by plugged in power plug and there are still old values visible?
                Did he run all needed adjustments in the right way?
                If assembled/ adjusted in the right way, maybe your main hv pwb can be related., have seen similar prints several times.
                You has to mount new pwb and running from all adjustments again.
