Kyocera M6630cidn No Paper Message
  • CopyTech03
    • Jul 2020
    • 54
    [Misc] Kyocera M6630cidn No Paper Message
    Have a M6630, when the paper tray is full it works fine. When it gets below 1/2 full it will indicate "No Paper in Tray 1". Sometimes I can open/close the tray and it will feed a few sheets then give the message again. Replaced the feed roller assembly (with spring) and sep roller assembly (both new) and also tried swapping the paper tray. Firmware is up to date. Tech Support didn't have anything. Any ideas?
    • 8164
    Re: Kyocera M6630cidn No Paper Message
    Check the out of paper sensor arm is not bent, seen that cause this issue a few times.
    Item number 9.
    M6630 Arm.pdf
    • Profibastler
      • Nov 2014
      • 102
      For testing, clean the roller with isopropanol or better with rubber conditioner.
      When problem fixed, cahnge the roller
      • CopyTech03
        • Jul 2020
        • 54
        Has brand new roller assemblies
        • CopyTech03
          • Jul 2020
          • 54
          Item number 9.
          [ATTACH]59922[/ATTACH]
          Thanks. Wouldn't think it would be something like that with such few copies, but will give it a try.
          • csliao
            • Oct 2021
            • 33
            擁有一台 M6630,當紙盤已滿時,它可以正常工作。當紙盤容量低於 1/2 時,將顯示「紙盤 1 中無紙」。有時我可以打開/關閉托盤,它會送入幾張紙,然後再次給予訊息。更換了進紙輥組件(帶彈簧)和分離輥組件(都是新的),並嘗 試更換紙盒。韌體是最新的。技術支援什麼都沒有。有什麼想法嗎?
            9. 302KV06341
              • 23008
              It's not about number of copies, it's about how aggressive the enduser is with the tray. =^..^=
              • ihatefinishers13
                Senior MFP Technician
                • Feb 2020
                • 707
                Item number 9.
                Have had this issue before! Might be one of the WORST designs for paper feed actuation I've ever come across.
                We had one similar where it would say to check cassette - ended up being how the separation roller unit was sitting. There's a spring loaded fin that wasn't in the correct place; and of course, the manual, per usual, showed nothing helpful.
                  • 898
                  I agree with it being a bad design but reading the manual it does show you that you have to have the cassette installed while putting the separation roller unit in . That was helpful
                    • 8164
                    Originally posted by csliao
                    9. 302KV06341
                    Yes, this is the part I was referring too, should be dead straight.
                    KYO-302KV06341-Kyocera-302KV06341-Actuator-B-Ecosys-M6030cdn-M6035cidn-M6230cidn-M6235cid-M6530-.jpg
                    • Shane007
                      • May 2024
                      • 1
                      Item number 9.
                      Hi
                      Would you by any chance have a part number for this paper actuator. We have a doctor as a customer who exceeded the max paper in the tray and actually broke off the actuator arm also causing it to read empty when the tray was half.
                        • 8164
                        Originally posted by Shane007
                        Hi
                        Yes my previous post below I attached a PDF with the part number.
                        www.printerfirmware.co.uk
                        • copydocinc
                          • Mar 2015
                          • 263
                          There is a gear inside the printer that matches up with a floating gear in the paper drawer and it lifts the paper up.
                          If that gear has a broken tooth or teeth it will only turn the paper lift gear only so far, Hence it works when the drawer is full of paper
                          As the paper gets removed the lift gear has to keep lifting the paper, but a tooth is missing and won't lift it any more.
                          I have had to replace the gear in the machine that I am talking about. It is a real pain to replace, but at least check that gear out for possible broken teeth
                          Maybe even teeth broken on the paper drawer floating gear too.
