3552ci mpt alignment
  • mtcchuck
    • Oct 2016
    • 50
    Good morning
    Customer is trying to print an image on labels. The image is too low on the label. I have adjusted mm34 on both mpt(L) and mpt (L) 3/4 speed. I can move the image up and down the page in maintenance mode and on copies but not while printing from a PC. Is there a setting to make the machine use printer settings vs PC settings? I'm not sure what im missing. Any help would be greatly appreciated.
    Thanks in advance.
    Chuck
  • Prestige3613
    • Apr 2015
    • 14
    Re: 3552ci mpt alignment
    Originally posted by mtcchuck
    Good morning
    Thanks in advance.
    Chuck
    Hey there! Let me know if you figure this out, I'm on the same boat. 😅
    • 4Toon
      • Mar 2023
      • 103
      Does not sound like printer side. Check drivers. What are they printing from? PDF, word, google docs.... try a different format and see if anything changes.
      • Prestige3613
        • Apr 2015
        • 14
        You know how it is, customers always blame the copier. 😂
        They print pdf files and word but also from a program their company uses.
        I'll test different formats and files and try to pin point which is the one is giving them issues.
        Any other suggestions are welcomed.😁
        • tmaged
          Owner/Service Manager
          • 1858
          Print to PDF and save the file to a flash drive and print from it. That eliminates any possibility of the driver causing it.
          Hope that helps !
          -Tony
          www.dtios.com
          Become a fan on Facebook
