White print 2554ci
  • Exodia-P4
    • Jan 2023
    • 135
    White print 2554ci
    Hello everybody
    I have a problem quite infrequently on a 2554ci but the customers call me and I don't know what I can do.
    When the customer copy an document, the paper take out of DP correctly and the print is completly white
    The DP is an 7160 and the copy is just in front and not the both sides. (Yes the paper is correctly put un DP ).
    The 3 time I came, I don't observed this error (Since installation, it's arrived +/- 6 times).
    I just update firmware (with take off ESKIP.on) 4 month ago... and my customer called me today and I don't know what I can do.
    According to them, it's arrived just in copying and not scanning... (color or black, A4).
    Have you an idea ?
  • Exodia-P4
    • Jan 2023
    • 135
    Originally posted by Exodia-P4
    Hello everybody
    Have you an idea ?
    Hello,
    I again have this problem at the same customer... nobody have en idea ???
    • ihatefinishers13
      Senior MFP Technician
      • Feb 2020
      • 726
      I haven't worked on the 54 series, but I've heard of weird issues on older versions. Reseat the connectors between the DSPF and the main body, especially if there is a small PWB for the DSPF that mounts on the Main PWB, reseat and blow out connectors for that, too. After that, gotta start with replacing the DSPF pwb, then if there is a small driver PWB for that DSPF, then the Main PWB.
      • ntbann
        • Jan 2012
        • 632
        We have also notice that when you tighten up the screws on the small PWB that mounts to the main PWB you have hold the board when you tighten them down or the board will cock a little causing strange issues. The mount holes have a lot of play.
        • justanotherhack
          • Apr 2015
          • 74
          We've seen this on a couple of 4003i machines, the drive belt for the scanner was too tight, I had to loosen up the motor mounts and give the belt a little slack.
          • Black Cloud
            • 176
            The scanner may be stalling under the white level strip.
            Net+ PDI+ @Remote
            • Exodia-P4
              • Jan 2023
              • 135
              Maybe It's the problem... But I never observed the problem.... So I cant look the scanner position
              • Exodia-P4
                • Jan 2023
                • 135
                Thank you, I will try It
                • Exodia-P4
                  • Jan 2023
                  • 135
                  Thanks, I will try It
                  • trunghuynh20202020
                    Technician_kyo
                    • Oct 2021
                    • 22
                    Could be optical sensor number 6
                    Try cleaning it and pay attention to the light or unintentional impact on it
                    Good luck
                    • dalewb74
                      • Feb 2018
                      • 1167
                      does it work when you lay the original on the platen?
                      • Exodia-P4
                        • Jan 2023
                        • 135
                        According to the customer, the problem come just on the ADF
                        • Lunatech
                          • Oct 2012
                          • 218
                          For what it is worth I feel it should be stated that it is easy for a user to place the original incorrectly and copy the blank side. I have witnessed it, I have done it. I am not saying this is the fact of the matter but rather a possibility.
