CS 3510i C3300 error code
  • Samanator
    • Sep 2017
    • 579
  • subaro
    • Oct 2010
    • 1274
    Re: CS 3510i C3300 error code
    Actually ,Kyocera told you the next step, but you forgot. The mainboard . The ISU board is connected to the DPRPWB, then from there to the mainboard. First I would check the ribbon cable from the lamp to the ISC PWB board ,i.e continuity check. The DPRPWB, is probably a relay board, so that should not be a problem . Also disconnect all the connectors from the main pwb and reconnect them. I am looking at this from the wiring diagram of the connections to the lamp. Also make sure the scanner motor is moving smoothly when you move the lamp by hand.
    • Ropariva
      • Mar 2016
      • 673
      • KYO_OEM
        • Aug 2011
        • 714
          • 23007
          I like this one. Perhaps the shading adjustment cannot be successful because of direct sunlight into the scanner cavity.
          On a tangent: I had a Mita many years back that was having continual replacement of drums. The machine was at a dental office with glass walls on three sides and the ceiling. On one of these visits it was a very bright sunny summer afternoon, and I was blinded by the direct sunlight in the room. Direct sunlight was shining in through the cracks around the covers, and light shocking the drum for hours at a time in the afternoon. The customer would not move the machine, of course. The solution was aesthetically not very pleasing. They wrapped the seams where the covers meet with a layer of duct tape. Thankfully, I never got to see that machine again. I'd imagine removing covers would be a chore with all that duct tape on it.
          • nathicana
            • Aug 2008
            • 335
            Try a different glass if you have one. That's assuming you have already cleaned the underside of the glass. There was a smaller machine that would give a lamp code due to the glass being grimy but it was hard to tell by looking.
