cs 2550 c6000 code
  • Copychick
    • Oct 2008
    • 19
    cs 2550 c6000 code
    This machine had a c6000. I tried resetting in u163 but it wouldn't work. I replaced the fuser with a new OEM, machine ran great.... for one day. The code came back again! Any ideas, perhaps main board?
    Please help!
    • 23009
    Hey Copychick. Long time-no see.
    These machine run quite hot. Try lowering the fixing temperature, and replacing the thermostat. This will solve some other issues also. =^..^=
    • Copychick
      • Oct 2008
      • 19
      Thanks blackcat- I thought you would respond with an answer for me! So by how much would I lower the fuser temp?
        • 23009
        Between 5 to 10 degrees Celsius. Just make sure that your copies are still fusing. And if your enduser is using heavy paper they Must select the correct media type. =^..^=
        • Copychick
          • Oct 2008
          • 19
          Thanks again!!
          • Ingersoll
            • Nov 2008
            • 74
            Have you heard of a door interlock throwing a C6000 code on a CS-3035
              • 23009
              No, but it makes a certain amount of sense...
              It's common practice to have a door interlock cut power to the fuser and/or high voltage to protect the enduser when removing jams. =^..^=
