FYI CF610
  • madas
    • Aug 2008
    • 313
    FYI CF610
    Hi all
    Error CF610 KM-3060, would not clear with reboot of m/c
    Told was resolved by doing Sim 989 HDD scandisk (I was not the tech so just basic info)
    madas
  • aabarnes1
    • Mar 2009
    • 620
    Did you format the HDD?
    Grant me the serenity to accept the things I cannot change.
    • madas
      • Aug 2008
      • 313
      Hi, I did not do the work but was told they only used scandisk U989 and did not format the HDD.
      To format the disk you use U024.
      U989 HDD scandisk
      Description
      Restores data in the hard disk by scanning the disk.
      Purpose
      If power is turned off while accessing to the hard disk is performed, the control information in the hard disk
      drive may be damaged. Use this mode to restore the data.
      madas
        • 23010
        Thanks madas. I've been documenting cfxxx codes for a while now (since the manufacturer doesn't care to). Whenever you figure one out, please let me know. =^..^=
        • madas
          • Aug 2008
          • 313
          Hi Blackcat, no worries! all for the common good LOL
