Taskalfa 500ci not booting up
  • brancas
    • Jul 2009
    • 80
    After installing a new engine board and new hard drives on a Taskalfa 500ci, machine was stuck on welcome screen. Switched machine off and on it then displayed C0640 error code. Formatted hard drive now machine is stuck on "now restoring data to hard drive" By the way its a new machine
    • 23008
    You need to reload firmware immediately after replacing the engine board. You can still reload the firmware.
    There are two different types of engine PWBs. Did you order and install the same type? =^..^=
    • brancas
      • Jul 2009
      • 80
      version 8 firmware was loaded.
      PARTS PWB ENGINE ASSY SP
      2H794070 was the part ordered
        • 23008
        Current firmware is v. 9.01
        Did the old PWB have 2H94070 printed on it?
        • brancas
          • Jul 2009
          • 80
          there was no part no. just a serial no.
            • 23008
            I wonder if I'm interpreting this tip wrong...
            There is definitely a different engine board for the lower segment machines than the higher segment machines. From a certain point of view that's two different engine boards. The parts manual lists only one part number for the higher segment machines-the number you ordered. OK, so disregard the second suggestion.
            Did all the firmware successfully load? Pay particular attention to the last screen. Which one or ones failed? If it's engine or Hi voltage that fails, you may need to contact the hotline to get a special form of the firmware with engine firmware only. And no, you can't just pick out a single file to load. You'll load the special firmware first, then if that succeeds load the combined firmware. =^..^=
            • spannerman
              • May 2009
              • 2
              Did you swap the eeprom from the old board to the new?
              • brancas
                • Jul 2009
                • 80
                installed ver 9.01 firmware and re connected connections to engine board, machine working, thanks 4 the info.
