KM2530/3530/3035etc...chgr arc
  • Rigger
    • Mar 2007
    • 30
    I have recently started selling three year old, off lease, Kyocera Mita, (2530. 3530, 3035, 4030 etc...) copiers. I have seen arcing ruin several drums and one time blow a main board. Are these bad copiers? Should I sell a different brand? The local dealer says these are great copiers.
    What!!!!!
    Rigger
  • dbrownlee
    • Sep 2005
    • 197
    We've got a few out, all under contract, and we go put the toners in for them, just so they see us once in a while. Very few troubles. Make sure that the grid and charge are dry after cleaning, I've read that people have trouble when they are used too soon after cleaning with the alcohol "wiper".
    GO TIGERS!!
    • Mark B
      • Jul 2006
      • 153
      They are very good machines. Replace the charge wire about every 40K and it will run well.
      • pjdbm
        • Sep 2007
        • 360
        Great machines! do not use the cleaning kit that comes with the 4035. Clean the charge with a blower not the stuff they give you other wise you will get arcs.
        • cboucher
          • Aug 2025
          These are great machines as long as you stay away from non-OEM toner...
          • dwparker.wa
            • Mar 2007
            • 33
            If you can, you might want to replace the main coronas before you send them out or at the next call. The corona isn't that expensive but it can cause all manner of problems and Mita just announced that the PM kits have a 3 year warranty life.
            • kyoceradude
              The Great Gazoo
              • Aug 2006
              • 442
              They have always had a 3 year or 400k-500k warranty. That is only good and valid if you renewed the warranty by replacing the maint kit @ 3 years or max copies WHICH EVER COMES FIRST. You can have a machine with 200k and void the extended warranty because you did not replace the kit within 3 years and 1 month after the original install date. No warranty is given (other than 30 days from purchase) on a maintenance kit being used to refurb a machine to resell..... Don't kill the messenger, check it out with your rep.....
              All Falcon I machines are out of warranty unless you replaced the kit when you were supposed to.... again 3 years or max copies on PM cycle, which ever comes first.
              My mission here on Earth is to help all you Dum-Dums!
              • just a tech
                • Jan 2007
                • 332
                i've found them to be very reliable machines..especially the 30,40,and 5035 series..just keep up with p/m's,keep em' clean, and instruct customer properly of the charge cleaning procedure due when they replace toner..(and if they forget,the instructions are in the box with the toner,grid cleaner,and two waste toner bottles.)never really have a problem as long as they let the charge unit dry completely before reinstalling...
                • Rigger
                  • Mar 2007
                  • 30
                  Thanks for all the responses. I feel much better about selling them.
                  Rigger
                  • konitech
                    • Jun 2007
                    • 20
                    the cleaning kits
                    the cleaning kits are fine....what kills the units is when customers don't use the kits when replacing their toner...
                    • leroyal
                      Expert on The Obsolete
                      • Sep 2007
                      • 156
                      Open all boxes of toner, before they are shipped out, and throw away the grid cleaners, put a spare waste bottle in the box.
                      Show the customer how to clean the charge wire and slit glass.
                      Now the customer won't call you for a long, long time, if ever.
                      Proven sucessful.
                      I know what I know better than anyone else knows what I know.
                      • Julio119
                        • 24
                        great product
                        I agree this machines are great. if you have a lot of problems with off the bad, make sure you test the machine before it goes out and if the machine is fine and has issues after a service call question your tech. I've service this machines for sometime now and its a good product.
                        Julio
                        Julio_119@yahoo.com
                        • Sathsayin
                          • 21
                          Whenever you install the mk kits make sure there isnt excessive paper dust inside the drum area. charge can ionize the paper dust and conduct straight thru the drum. Technicaly the drum and charge work like 2 plates of a capacitor. the potential is what charges the drum. If there is ecessive matter (paperdust/trash) its possible to short out conduct thru.
                          I want to choke the axxhole who designed this!!!!
                          • Sam Tofu
                            • Dec 2007
                            • 130
                            We have also gone to having customer call us when time to replace toner.
                            After drum arcing problems due to their not being comfortable with the cleaning, we just take a few minutes and do it. Good PR anyway.
                            Hey thanks for the tip on blowing them off instead of the cleaning pads with alcohol.
                            Also we have found the customers don't make certain the charge is anchored (locked) back in and then we get calls for light copies or other copy issues.
                            • Copydoc Ric
                              Intake Filters
                              Be sure the intake filters are clean. They are located on the right side of the machine. If these are not they can cause toner to build up on either end of the primary grid.
                              Doc Ric
