Multiple senders for scan to email from a task alfa
  • n25an
    • Jul 2008
    • 1030
    Is there a way to setup multiple senders for scan to email on the task alfas... I checked with the help desk and they said no. But if it is possible I figured someone here might know...
    Sad To Say I Don't Have a Life
    I do this stuff on the weekends too
    • 22999
    If you enable User Login the machine will use the email address of the logged in user as sender. See pg 414 of the Operators Manual.
    How badly do they want to change the sender? User Login quickly frustrates even the most dedicated user. =^..^=
    • n25an
      • Jul 2008
      • 1030
      question
      does the user login allow for athentication of the email address... or does it have to be a no authentication situation?
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1870
        No, it'll just show that it came from that user. It's still using the account that's set up in the SMTP settings to send.
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
        • n25an
          • Jul 2008
          • 1030
          interesting... I will check this out over the weekend... thanks again...
            • 22999
            If you decide to use this, I recommend that you use numeric characters for your username and password, and keep the entries short. They can be entered from the number keypad quickly. If you use letters they must be entered from the dinky panel keyboard, and you'll end up replacing touch panels regularly because of the additional wear and tear. =^..^=
