DF-710 on a CS-C4035E - - - C8140
    • 23008
    [Error Code] DF-710 on a CS-C4035E - - - C8140
    I PM'd the machine Tuesday, and saw a few occurrences of the C8140. Once the machine was back online, it ran at least 1/2 hour continuously with no errors or jams. So far, so good.
    Callback today, yes: C8140. I found a way to duplicate the problem. When copying 20 originals, 3 sets, the first two sets eject correctly. The third set errors out.
    I've tested the various switches in sim U241 (TRAY L-LMT, TRAY U-LMT, TRAY MIDDLE, PAP H DOWN). All test OK.
    I've tested the tray A lift motor in sim U240 (FINISHER MOTOR/TRAY MT). Up, down, up, down, up, down ... etc. Tests OK.
    I've tested the hold down solenoid in sim U240 (FINISHER SOL/HOLDOWN SOL). Click, click, click, click ... xtc. Tests OK.
    After watching for a while I can see how it's supposed to work:
    1) tray A homes to upper limit
    2) finisher feeds out multiple pages (1 complete set)
    3) tray A lowers 6mm
    4) hold down solenoid lowers hold downs onto paper
    5) tray A lifts ~2mm to trip paper hold down sensor
    back to 2)
    When it errors:
    2) finisher feeds out 1 page
    3) tray A lowers 125mm
    4) error is displayed
    I had come to the conclusion that it was a finisher controller error. Just to be thorough I reloaded the firmware. That was the last time I saw the problem.
    Hundreds of pages and no errors. So the real question is: Did I fix anything? =^..^=
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1885
    I've fixed things with a firmware update that I didn't think would make a difference. I've also had the same problem after a firmware update that I was sure would fix it. Now if you'd done nothing & it stopped...............
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
      • 23008
      Update: The callback took ~4 hours.
      Finisher Main PWB installed today. No codes after 35 minutes of printing. Time will tell ... =^..^=
        • 23008
        Update: This callback took a whole day to arrive.
        I took a different approach today. Just to rule out any mechanical failure I completely disassembled the screw gear drive to tray A. As I was fiddling with it, observing nothing out-of-the-ordinary, I happened to notice that the tray was still sitting at the top of it's travel and had not budged. Owing to gravity, the tray should have dropped.
        The timing belt drive that raises the tray did not turn easily. This belt has a self-tensioning spring and a screw to maintain the tension. So I loosened the two screws letting the spring adjust the tension, and the tray dropped. Letting the spring do the tensioning, I snugged up the screws. After that it moved much easier, and dropped to the bottom of it's travel every time. I'm thinking that the additional drag on the motor was causing an over-current condition on long print runs.
        My other idea was that the DC motor was just failing, so I swapped the tray motor with the like finisher across the way.
        So if the code jumps to the other machine, it is the motor.
        If the code just disappears, it was excessive belt tension.
        If the code comes back ... well I don't know. It's been two whole days. I'm crossing my fingers. =^..^=
          • 23008
          Update: 5 days and no callback. I'm cautiously, optimistic. A couple more days and I'll clear the call. =^..^=
          • GESPAGE
            • May 2011
            • 40
            Re: DF-710 on a CS-C4035E - - - C8140
            DF-710 C8140
            • wragsdale
              • Jul 2014
              • 188
              Holy Necro...
                • 23008
                Are there any French speakers here? =^..^=
                • wragsdale
                  • Jul 2014
                  • 188
                  Google's (hilarious) attempt:
                  becomes sticky foam, prevents the proper functioning of the coil
                  finger jogging copy output
                  • MFPTech
                    • 486
                    Has this Error code been fixed please? I am fighting C8140 in a Finisher attached to a TA520. Thanks in advance!
                    Sent from my SGH-I337M using Tapatalk
                    • subaro
                      • Oct 2010
                      • 1274
                      back to 2)
                      When it errors:
                      kyocera has a few bulletins on this code. unfortunately i cannot post them as to my contract.
                      But i can point out it mentions,
                      1. worm gear check for wear .the tray lift gear
                      2. Tray not installed properly. there is some mylar to add to better sense the tray.
                      3. The solenoid spring correct installation. Check the solenoid spring that it is moving freely. Also in the past some of out techs has replaced the solenoid itself, because of excessive magnetization. sometimes the plunger cannot be removed, its stuck in there magnetized, when in fact it should move freely in and out.
                      I would replace the solenoid first. just my take.
                      some kyocera friends may want to pass on those bullentins to you or the forum.
                      • MFPTech
                        • 486
                        I am a certified kyocera tech with full access to KDA connect, any idea where exactly to look for those bulletins please?
                        Thanks in advance!
                        • subaro
                          • Oct 2010
                          • 1274
                          Thanks in advance!
                          It's on the ASTEA website. you type the same address www.kdaconnect.com, but you have to use the windows explorer browser. You can alternatively open a ticket by calling kyocera usa and mention the error code. You should ask them about login to the ASTEA website.
                          • MFPTech
                            • 486
                            on the ASTEA i found that i had this error 3 years ago and fixed it by replacing the tray A motor.
                            • subaro
                              • Oct 2010
                              • 1274
                              When you solve this current problem, post with the fix. It may not be the same fix as three years ago, but then again it could. let the folks know.
