Taskalfa & Voyager black smudge
  • jmaister
    certified scrub
    • Aug 2010
    • 755
    [CQ] Taskalfa & Voyager black smudge
    looks like a dot, then spread a bit toward trailing edge.
    Anyone can edu-mah-cate me on how and why this happens as well as the remedy?
    Idling colour developers are not healthy developers.
    • 22954
    I call these "comet-trails", since they have a teardrop shape that fades out towards it's tail.
    It's overtoning. Replace the developing unit of the color of your spots, then do a color calibration. =^..^=
    • tmaged
      Owner/Service Manager
      • 1862
      The new TASKAlfa firmware version 11 addresses the problem. It also says there will be a bulletin to address it. It could be the cleaning motors also. Have fun doing those !!
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
      • jmaister
        certified scrub
        • Aug 2010
        • 755
        Eh...firmware is no help in this matter.
        Don't really have a reason to replace devs if happens intermittently.
        Any adjustemnt I could do?
          • 22954
          Nope. Overtoned developer cannot be adjusted leaner, just replaced. Guaranteed, it will get worse.
          Oh, An interesting bit of trivia:
          On VoyagerE's, overtoning cyan developer can cause magenta comet-trails (or any other color). Look at sim U131 to identify any colors more than 25 points different than the reference. Those are the ones in need of replacement.
          • tmaged
            • 1862
            Yep, replace the DV unit & upgrade the firmware to keep it from coming back.
            Hope that helps !
            -Tony
            www.dtios.com
            • ignacio.cortez
              • Jul 2010
              • 176
              Just spent a Day with a Kyo rep, they call it Toner Bombs or something like that, that is what he told me, Replace the DV Unit (of the color of the Toner Bomb) and update to Firmware 11, As stated earlier, Firmware 11 compensate for this. I dont remember if the DV unit will use a new number or the same, I just sent him an E-mail (I have a client that is doing just that and I need to order it)
              • LNorris
                • Sep 2008
                • 645
                just had this happen as well. my rep handed me a new t/sing guide for the 500ci. it was just posted this weekend on kmaconnect. helped me. u325 will need to be changed as well.
                • luis8832
                  • Dec 2008
                  • 250
                  yes kma connect has the 500ci troubleshooting guide and it shows the issue at hand.
