Copy star vs kyocera 5050
  • Mark B
    • Jul 2006
    • 153
    We recieved a copy star 5050 (A dealer split) and we are Kyocera dealer. Are the flashes and toner the same. What other problema will we run into.
    • 23008
    No and Maybe...
    The toner is definitely not the same. They changed the drive coupler so it won't add. The chip is the same.
    I don't know if the flash is the same or not. Logically there shouldn't be any difference, but when did logic ever apply to copiers.......
    • just a tech
      • Jan 2007
      • 332
      according to kma, it's the same flashes for both..speaking of which-- a new firmware version was released on 10-8-07..good luck..
      • Mark B
        • Jul 2006
        • 153
        The machine was setup and no problems with the toner or flash. Thank you for the input.
