We recieved a copy star 5050 (A dealer split) and we are Kyocera dealer. Are the flashes and toner the same. What other problema will we run into.
Copy star vs kyocera 5050
No and Maybe...
The toner is definitely not the same. They changed the drive coupler so it won't add. The chip is the same.
I don't know if the flash is the same or not. Logically there shouldn't be any difference, but when did logic ever apply to copiers.......If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
according to kma, it's the same flashes for both..speaking of which-- a new firmware version was released on 10-8-07..good luck..Comment
