CS-400ci with c-2810
  • Dave10
    • Jul 2008
    • 197
    I had a 400ci with a c-2810, waste toner motor problem. It has the spring in the waste toner assy. I checked the motor and it was bad , so I replaced it. The new motor now ran constantly, and still had a C-2810. I replaced the engine board. Same problem. I have checked all the waste toner tubes, etc., and the belt. Nothing is clogged or hard to turn. I called the Kyocera hotline, and they said there are no other possibilities and I need to replace both the motor and board at the same time. Anyone have any other ideas? I know it's a pretty simple circuit, but maybe there are other things I am missing. Anyone had this and found a different fix?
    • 23009
    This is extremely common on the VoyagerE series. The shorting motor takes out the engine board. The bad engine board takes out the waste toner motor. If you replace both as a set, simultaneously, you'll have it. Also check that the transfer waste drive can turn manually, and is not clogged. =^..^=
    • JSC
      Gimp
      • Dec 2006
      • 618
      Blackcat4866 is spot on, Iv'e have had to do a few of these now, I have just noticed they have up graded the motor check out the pdf, but be aware its a uk part number
      The gene pool could use a little chlorine.
