KM 5035 Resetting drum and dev counts
  • gwaddle
    • May 2009
    • 782
    I'm trying to remember how to reset the drum and dev counts on a KM5035. The book says to press the reset key then the print key after you are in the sim, but it doesn't reset it. Maint count reset fine. Any tricks out there? Thanks.
    I know I should be ashamed of myself. Strangely though, I am not.
  • kyocera.team
    • Aug 2010
    • 126
    Re: KM 5035 Resetting drum and dev counts
    my friend
    drum counter rest by sim u110
    developer drive time rest by sim 157
    good luck
    • Metalvoc
      • Sep 2008
      • 155
      I don't believe you can manually reset the Drum or DV count on the 5035. These models had chips on the different units with counts on them. I just tried resetting the 4035 we have in our shop, with the same outcome. Reset key does nothing. Think you've got to replace the units (or at least steal a chip from a new unit) to reset the count. DV Drive Time reset fine, but not the count.
      On a side note... I had to reset a fuser count on a FS-9530 while we were waiting for a new fuser to arrive. Customer had their shorts in a knot about the PM message. So I used some speaker wire with a couple leads on the end, and a push-button switch on the other end to close the fuse link circuit on the fuser board. I just pressed the button repeatedly during warm-up, and the count reset. I'm not sure I would recommend this as a solution, unless you are really determined, or really desperate.
      I must have a prodigious quantity of mind; it takes me as much as a week sometimes to make it up - Mark Twain
      • gwaddle
        • May 2009
        • 782
        Thanks for the replies.
          • 23009
          I concur. =^..^=
          • kyocera.team
            • Aug 2010
            • 126
            no my friends we can reset it manually :-)
            • gwaddle
              • May 2009
              • 782
              Just out of curiosity, why then are there sims to reset them?
              • Metalvoc
                • Sep 2008
                • 155
                Vestigial structure...? Older models allowed you to reset via those sims. Perhaps they just didn't think to take the sims out of those models, or perhaps it is just so you can see the counts on those units, allowing you to be proactive with the service.
                • Chipburner
                  • Aug 2011
                  • 1
                  Just enter Service Mode with 30363036 then you can run the Sim U110 and so on and enter what you want
                  • Venom
                    Technical/IT Support
                    • Nov 2009
                    • 765
                    Agree 30363036....too bad the falcon 4 wont reset that way
                    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
                    • jhon paulivan
                      • Dec 2011
                      • 18
                      how about KM 4050 ?
