Kyocera 2560/3040/3060 "Gray backgrounding"
  • Faxman63
    [CQ] Kyocera 2560/3040/3060 "Gray backgrounding"
    PrimaryKyocera 2560/3040/30602560 rear cavity.jpgtwo fingers
    • 23010
    Re: Kyocera 2560/3040/3060 "Gray backgrounding"
    Good find. I've seen a few of these that have begun arcing between that primary contact and the primary charge unit. On those I took a diamond file to remove the corrosion, and reshaped the contact for better ... contact. =^..^=
    • dickierock
      • 252
      Hi,had this a bit as well.Also if you examine the black holder behind the contacts,there is a cavity there that allows the contacts to slip into space,hence poor contact with the main charge.The solution is to cover the cavity with something like a small plastic stickybacked strip.
      • kyocera10
        • Sep 2011
        • 13
        sometimes the main charging arcs, you just have to file the burnt edges and it should be fine
