Hi i was hoping someone has had this problem before its on a DP-750 attached to the TA250ci.The issue is the lift motor does not lift the plate up to allow the original to enter the DP.
Trying to test it in sim mode the motor does not move,but if i move the white cam out if position then the dp resets its self, and moves cam back to home position and moves plate down(that tells me that the motor works)
The machine has only done 80k i cannot see any reason for the cam not to turn and nothing is stopping the plate from moving up to meet the dp feed rollers the dp registers paper and trys then jams.
Any idea's
Any idea's
