CS 3060 ????
  • copiman
    • Sep 2011
    • 861
    CS 3060 ????
    I know I am causing the problem. I cannot get into service mode. I pressed and released the status key, entered 10871087 and nothing. I even pressed and held the status key. Nothing. Can anyone tell me the trick to this? I am at a loss. This is my first attempt at this.
    Should the display change when any of the keys, three keys, to the far left are pressed? One of those is the status key.
  • Kidaver
    Ghoulscout
    • Apr 2011
    • 912
    Re: CS 3060 ????
    no trick to it....hit the job status key and let it bring up that function...then press 1087 1087....that's it...nothing else to it
    "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
    • Copystar Tech
      • Sep 2010
      • 59
      Re: CS 3060 ????
      Unless you have a dead op panel. The display should change to a job list when hitting status, and the 10871087 should give audible beeps. (depending on audio settings) If not, might have a corrupted panel, might have to do the whole boot switch deal. There are many threads on this already, so I digress. Point being, yeah, the display should change in status.
      Oh yeah, forgot to mention, you most likely didn't cause this, unless you killed the power during an upgrade, yanked the stick, etcetera. Common problem of failed DIMMS and Hardrives.
      • Dougtech
        • Apr 2011
        • 113
        Re: CS 3060 ????
        yes the display should change when you hit status button, copy, send, or any of the buttons on the left side.
        • pjdbm
          • Sep 2007
          • 360
          Re: CS 3060 ????
          another way to get into service is open front door and do the 10871087
          why the panel is not working is something else you will have to find out.
          • copiman
            • Sep 2011
            • 861
            Re: CS 3060 ????
            Thanks Copystar Tech. Can you elaborate on "whole boot switch"? Not sure what or how to do as well as what it affects. Thanks again.
            • Copystar Tech
              • Sep 2010
              • 59
              Re: CS 3060 ????
              Here is a link to a discussion on this forum. Before I would do that, I have seen a couple of times that some of the connectors loose themselves causing this problem. (downfall of a multi-position op panel, I think) I would pull the op panel and reseat all the connectors.
              • Copystar Tech
                • Sep 2010
                • 59
                Re: CS 3060 ????
                here's another nice discussion about op panel woes.
                • copiman
                  • Sep 2011
                  • 861
                  Re: CS 3060 ????
                  Found the problem. Turns out, the customer does alot of job cancels, which requires them to select the status key. When they select to cancel a job, they continue to press the key several time a little harder because it did not immediately stop printing. I resoldered the the switch and Walla. All is good today. They will be gentle in the future.
                  THANKS everyone for your help.
                  • Copystar Tech
                    • Sep 2010
                    • 59
                    Re: CS 3060 ????
                    Didn't see that one coming, good find and thanks for sharing the solution.
                      • 22973
                      Re: CS 3060 ????
                      Thanks for sharing your solution. =^..^=
                      • copiman
                        • Sep 2011
                        • 861
                        Re: CS 3060 ????
                        Thanks everyone for your help. Love this site. I wished everyone would follow up and post what the final fix was. This would not only help the tech that is having the issue, but it would help all. I look at the post that pertain to the equipment I service and learn alot. SPREAD THE NEWS!!!!!
