taskalfa 500ci firmware stuck on welcome screen
  • stevegibsons
    • Jun 2012
    • 12
    Hi we have a taskalfa 500ci stuck on welcome screen looking for the firmware to try a reflash it have access to utax firmware for equivalent machine not sure if it is the same any help would be much appreciated
    • 23010
    Re: taskalfa 500ci firmware stuck on welcome screen
    The actual firmware should be correct. I install Copystar firmware in Kyocera Mita & Copystar MFPs, with no problems. But the display language must be correct. Chinese or Swahili firmware might restore your machine, but who would read the screen for you? =^..^=
    • stevegibsons
      • Jun 2012
      • 12
      Firmware is ok for uk as downloaded from Utax just seems to get stuck when firmware loading message about panel error tried cf and USB uploads of ver 5
        • 23010
        Do you have access to the hotline? What you need is Engine firmware only with the associated files. Once that loads correctly, then you can try to load the full version firmware, then upgrade as necessary.
        If this fails, you may need to replace one or more of the following items, then re-try with the same procedure:
        CODE DIMM
        HDD
        Main PWB
        Do you know which firmware fails? Does it even start? It can take as long as 45 minutes, so don't get too anxious and stop it early. I wait at least 60 minutes before I consider shutting off. =^..^=
        • stevegibsons
          • Jun 2012
          • 12
          Not sure if firmware is starting switch dip switch on panel pcb to boot leave it for about 20 minutes after light stops flashing then switch to normal and try to boot first engine&pannel firmware from cf but after about 15 min get error message (will check tomorrow and let you know what it says) about 3 missing files does the same thing if you try to load from USB at port at back both are formated in fat also does same if you try to load all firmware with same message trying ver 5 believe higher version need this first. This is the first time had welcome screen error
          • Paul 75
            • Oct 2008
            • 97
            Just a quick note on this one. The latest firmware on this is v13.0010 .
            Oh...... I can't copy at the moment then ? !!!!!!
            • stevegibsons
              • Jun 2012
              • 12
              Hi the message is firmware update . panel cpu error ,server ip not found ,complete file not found, panel end file not found.
              We also have ver 13 of firmware but have a tech note that ver 5 needs to be installed first do you know if this is correct
              • ss12
                • Jul 2008
                • 289
                Had the same problem recently,ended having to replace the control panel & the dimms
                  • 23010
                  The advisory is a little unclear.
                  Yes, version 5 is required before version 13 (if you have a version below 5). But if you have any version above 5, you can go directly to 13.
                  Most of my machines get updated only one level at a time. I've gotten recommendations from other techs to do all upgrades. Jumps of 3 levels of firmware have resulted in crashes.
                  Now back to your problem: You could have a bad panel PWB. =^..^=
                  • stevegibsons
                    • Jun 2012
                    • 12
                    Tried code dimm no luck does anyone have mita flowchart that is talked about in this forum
                    • ss12
                      • Jul 2008
                      • 289
                      try this link it has various soloutions http://www.copytechnet.com/forums/ky...me-screen.html
                      • stevegibsons
                        • Jun 2012
                        • 12
                        finally got machine to take firmware now getting c0640 error any idea?
                        • ss12
                          • Jul 2008
                          • 289
                          c0640 hdd problem-see if you can do sim917 (backup address book data & other stuff) onto a usb stick.Then try sim24 hdd format
                          • jmaister
                            certified scrub
                            • Aug 2010
                            • 755
                            Hiya gents.
                            Anyone has insider why this happens? Any gurus outthere on this?
                            Idling colour developers are not healthy developers.
                            • kkendric
                              • 301
                              Hard Drives are mechanical assemblies that generally spin at between 5,400 RPM and 7,200 RPM. They work as long as the copier is on. These newer copiers are set up so you should power them down from the power button on the operation panel before you turn the power switch off, does youe customer do this? This is to allow the Disk Drive to shut down correctly. If the disk drive is constantly shut down incorrectly it may cause the head to crash and also cause more errors on the drive. Which can shorten their life.
