TA 250ci ace tech needed
  • blackdog
    • Jun 2012
    • 211
    Hey, was at a customers office for a few hours today trying to resolve this issue;
    Getting a void 3/4 inch wide with what I call pencil lines right down the middle of the void of a letter size copy on glass or adf, prints are awesome. This void does not move or change shape or size, always smack
    down the middle. I've done all the obvious. This anomaly looks similar to a fuser finger gouge.
    Box has 98k, still a baby TA.
    I bet Blackcat or Venom has the answer.
    • 22932
    Re: TA 250ci ace tech needed
    hmmmmm.
    To recap: So prints are normal/good. Reports are normal/good. Copies from glass or DP have a void 3/4" (19mm) wide with "pencil marks". Void stays in the same place.
    Clearly it's a scanning issue. I'm not too clear on what's obvious to you. Personally, I would:
    1) clean all optics. I'd also remove the plastic cover that bridges the gap between the lens and CCD. From there you can inspect/clean the lens and CCD lens array. (I think this is where you'll find your problem.) Do not adjust or move the CCD in any way, unless you want additional problems to solve. I think you have enough challenges here already.
    2) scan a document to my SMB folder. I'd try different DPI settings. Is the problem present?
    3) reduce/enlarge. Is the problem present? If it's something optical like dirt, changes to DPI should make little difference, changes to reduction/enlargement: the anomalie should stay proportional in size with the rest of the image.
    4) With power Off, I'd re-seat connectors to the CCD, scanner PWB and main PWB (be extra careful with the ribbon cables).
    5) If none of that worked, I'd re-load firmware.
    6) If I was still nowhere, I'd start changing parts: scanner PWB, CCD, main PWB in that order.
    Did I include some of the obvious? And tell me more about these "pencil lines". Can we see a scan or photo? =^..^=
    • blackdog
      • Jun 2012
      • 211
      hmmmmm.
      Obvious; Cleaned optics, checked transfer, fuser, dev & drums.
      I can't picture that plastic cover but I'm sure it will pop out at me when I'm back out there. And NO I will not attempt to adjust CCD (been there/done that).
      It looks like someone along the way has nicked a piece of the slit glass in corner at back of machine, but that doesn't seem to be having a negative effect.
      I'm going to include some images to this thread as soon as I get to my tool bag in garage.
        • 22932
        I've seen plenty of corners missing from the slit glass. As long as it will sit securely, and not snag the paper, I wouldn't worry about it too much.
        • blackdog
          • Jun 2012
          • 211
          TA250ci scan 2001.pdf
          I attached pdf images.
          Cleaned lens, optics as you suggested. Wrapped it up, turned on and C3300 (WHOHA). I thought it bit the bullet but I did the connector thing on the scanner boards and it booted. whew.
          Anyway check out these images one as a print and the other as a copy.
          Thanks, man
          • blackdog
            • Jun 2012
            • 211
            Originally posted by blackdog
            [ATTACH=CONFIG]22456[/ATTACH]
            Thanks, man
            I have no idea how that quality pdf got in there, pay no attention to it.
            TA 250 pdf is the correct one.
              • 22932
              The scan doesn't do it justice. Try a photo, and enlarge it. =^..^=
              • copymech
                • Sep 2011
                • 196
                Make sure the scanner lock isn't interferring with scanner movement.
                • blackdog
                  • Jun 2012
                  • 211
                  Hey Blackcat, I'm stopping by customer in morning. Do you think a sky shot would would be more defining?
                  Or how about a scan to folder?
                  Thanks for your feedback.
                    • 22932
                    I'd go with the SMB folder scans, and try some different scanner options. It will be interesting to see how resolution, file format, color/B&W, all affect the resulting scans. And you might get some fresh ideas.
                    • blackdog
                      • Jun 2012
                      • 211
                      When you say CCD Lens Array, am I missing something?
                      I am aware of mirrors, reflector and one lens.
                      • darry1322
                        • Oct 2010
                        • 817
                        Looks like it could come from shading. Make sure the shading sheet under the glass is good and you could try adjusting the shading position.
                        • blackdog
                          • Jun 2012
                          • 211
                          I see the adjustment for shading, but for the life of me I can't reference the location of this sheet you speak of?
                          • darry1322
                            • Oct 2010
                            • 817
                            It's the white sheet glued to the original glass. Remove the original glass and flip it over. It's the white strip.
                            KonicaMinolta trainers would sometime cover a section with electrical tape as a troubleshooting exercise. The copier would print internally OK, but copies would have a light streak.
                            You wouldn't see the tape unless you removed the glass and flipped it over to see the shading strip.
                              • 22932
                              AKA: white level reference.
                              And there is a focusing lens (hasn't changed since the analog days) and the lens array on the face of the CCD (part of the CCD PWB).
