FS-4300DN Fuser issues
  • nathansipe
    just another tech
    • Aug 2009
    • 122
    [CQ] FS-4300DN Fuser issues
    I have 2 Kyocera FS-4300DN printers in an office installed in October 2013 with 225K on each as of today. I know the yield for all the maintenance parts is 500K. Well, both of the upper heat rollers look terrible on the right half of the rollers. It's causing poor fusing and dirty prints down the left edge of the page. I plan on returning these for warranty, but has anyone seen this on these printers? If it were one printer, that's one thing, but both of them are doing it at around the same time.
    They run plain, letter paper only. Firmware is up to date.
    Other than this issue, these have run like a champ.
    Best rule for troubleshooting.
    K I S S Keep It Simple Stupid
    • 23009
    Re: FS-4300DN Fuser issues
    I checked the Release Bulletin, just because 500K sounds hugely unrealistic on a tabletop printer. It is accurate, but still hugely unrealistic. The KM-8030 fuser is rated at 500K, and built a whole lot differently. Regardless of what the bulletin says, I wouldn't expect more than 300K maximum. =^..^=
    • nathansipe
      just another tech
      • Aug 2009
      • 122
      I agree that it sounds too good to be true, but if they cover the warranty for 500K, then that's fine with me. Any table top printer that is 62 ppm, seems to good to be true anyway.
      • CWP
        • Jun 2013
        • 168
        There is a firmware update that is supposed to resolve that issue I think. Read the release notes for the firmware there is something in there about the heat roller getting stained and a firmware change to correct it.
        • nathansipe
          just another tech
          • Aug 2009
          • 122
          "Measure to prevent a stain
          on heat roller
          The fuser temperature may increase sharply when turning the power ON or returning
          from sleep mode, causing an increase to the heat roller surface temperature. As a
          result, fuser offset may occur. If this occurs repeatedly, the toner adhered on the heat
          roller surface may not come off and the fuser roller may be stained, or black
          streaks/bands may appear on the image due to the stain. This has been corrected.
          This problem tends to occur more often with intermittent output than continuous output."
          This was on the 9/13 firmware. I have the firmware from 12/13 that's even newer than that though. And the customer runs about 40K per month per printer, so the intermittent output doesn't apply either.
          I did notice that the part number has changed so that maybe they updated a part in the fuser unit.
          • Kyo fan
            • Dec 2013
            • 368
            They say it's 500k for drum and developer only, but like blackcat said, don't expect much more above 300k. I had few (FS-4200DN though) with similar issue of oem toner adhering to the heat roller at about 200k printouts. You can take the fuser out and properly clean the heat roller untill it sticks again and so on. Or you can replace it, up to you. Firmware or anything else won't help you with this.
            Overall, I am not really satisfied with these series when comparing it to the previous FS-4020DN, and when i saw the new mfp line built on FS-4200DN, i wasn't so happy about it, but that's just me.
            Good luck.
            • Frits
              • Jun 2009
              • 62
              In the first release of the printers the pressure springs are changed this is not common now only thing to due is replace the fuser.
              • Larhal
                • 584
                I had some 4200 do the same thing, Had to replace the fuser, under warranty from Kyo, and update the firmware. Units had 140- 160 K on them.
                Larhal
                Larhal
                If all else fails read the Service Manual!
                If that fails, meet me at the pub and we will discuss it.
                • HenryT2
                  • 962
                  When you log into KDA today; look for that new Firmware ....
                  There was a bulletin released today about that staining issue.
                  "The Serenity Prayer" . . .
                  God grant me the serenity to accept stupid people , the courage to not waste my time and energy on them , and the wisdom to know that I cannot fix STUPID .
                  • JustManuals
                    • Jan 2006
                    • 9838
                    This Parts & Service Manual can now be purchased for $14.77 and downloaded immediately from:
                    Paul@justmanuals.com
                    • nkot^1
                      • Sep 2013
                      • 17
                      Hello blackcat4866,
                      the Ricoh SP5300 is similar to the Kyocera FS4300.
                      And had the same problem.
                      Can you send me the bulletin?
                      That would be nice, thanks a lot!
                      • Geo
                        • 662
                        If you installed them in 10/2013 the warranty period has expired on this printer ..39 months max.
