TA 250ci E2770 error
  • Larhal
    • 580
    [Error Code] TA 250ci E2770 error
    Hi All,
    Little stumped here, We have a customer with a TA 250ci that has thrown an E code. E2770. Now we are Not Kyocera trained, Ricoh yes, but I cannot find this error code on the KYO site or in the service manual.
    Any help would be appreciated.
    Larhal
    Larhal
    If all else fails read the Service Manual!
    If that fails, meet me at the pub and we will discuss it.
  • copymech
    • Sep 2011
    • 196
    Re: TA 250ci E2770 error
    If machine firmware is not current it may give wrong error codes.
    • Larhal
      • 580
      Firmware Ver. 13 , current.
      larhal
      Larhal
      • Tonerkiller
        • Oct 2012
        • 668
        Look again, it is throwing a different code.
        • Larhal
          • 580
          Hi All,
          I was not the one to go to the unit, It was another tech, He emailed me the code and It was C2770, Transfer belt skew. Ok I know, it happen, Thanks for all your help anyway.
          Larhal
          Larhal
            • 23008
            If you've got a C2770 you don't have a Saturn. That code didn't exist yet. You've got an Alphard I or Alphard II, probably a Venus. =^..^=
            • Larhal
              • 580
              Hi Blackcat,
              In the service manual for the TA 250ci it shows that code, C2770 and is a transfer belt skew. It was do for a MK 865 A kit on the unit and when we did it the unit came back to life no issues.
              Anyhow, Thanks all for your input.
              Larhal
              Larhal
              • Paddy
                • Jun 2013
                • 9
                Hi,
                did some Research.
                In the Service Manual from Ta 250ci, there's no E2770 Error been noticed.
                "blackcat4866" was right on this. It might be the Zeus Series.
                Checked the Service Manual from TA 6500i.
                Here's what i found:
                • Larhal
                  • 580
                  I looked again, I found that my service manual, 3 ring binder type, has had some pages removed and replaced. The series numbers for the manuals are not the same on the top of the pages. ERRRRFFFFF!!!!
                  Got to keep my associates out of my stuff.
                  Anyhow. the MK A kit resolved the issue. Unit is up and running.
                  I hate it when people misuse my stuff, now I have to look through all my manuals and see what pages are not correct.
                  I stand corrected and thanks again.
                  Larhal
                  Larhal
                  • Scott
                    • 196
                    I cant find anything for the 250ci but here is the same code for the 3050ci...
                    • Tonerkiller
                      • Oct 2012
                      • 668
                      What is a 3 ring binder?
