C610 fuser error
  • Sharpshooterbds
    • Aug 2007
    • 10
    C610 fuser error
    Does anyone has the procedure for clearing a C610 fuser error on a mita KM-1810. Thanks
  • leroyal
    Expert on The Obsolete
    • Sep 2007
    • 156
    Burned out / broken fuser lamp.
    I know what I know better than anyone else knows what I know.
      • 23009
      When you solve your fuser problem, you can reset fuser errors with sim 163.
      • Sharpshooterbds
        • Aug 2007
        • 10
        Mita Fuser error
        Thanks but what is the procedure to perform the sim 163
        • ebm
          • Apr 2007
          • 183
          The correct procedure is to call a qualified technical representative. Especially with a fuser problem. The reason the fuser malfunction can only be reset by qualified technician is to prevent fire hazard.
          • leroyal
            • Sep 2007
            • 156
            Harumph!
            • Sharpshooterbds
              • Aug 2007
              • 10
              I think this a great site with alot of qualified technicians but we still need help from time to time on some of the weird faults we see out there. However, I dont think the lack of a manual makes a person unqualified
              • JustManuals
                • Jan 2006
                • 9838
                But just think of all the knowledge you'll get from a manual. It could be the best $11.77 you've ever spent.
                Paul@justmanuals.com
                • hardcore
                  • May 2008
                  • 26
                  Hey, Executing maintenance, Press stop/reset key, start key, and the left copy exposure adjustment key in the order presented and hold them down. press the stop/reset key. and select the sim mode of 163 press start. that,s it brother!!
                  • ebm
                    • Apr 2007
                    • 183
                    Some of the posts i read seem to be from "users" trying to repair, not technicians. Trained technicians should not need to ask for basic information such as how to enter service modes and reset codes. I thought this forum was for "techs" to trade ideas when they are stuck on a problem. Sorry if I offend anyone.
                    • Sharpshooterbds
                      • Aug 2007
                      • 10
                      C610 error code
                      I got it sorted but thanks alot hardcore.
                      • hardcore
                        • May 2008
                        • 26
                        Hey any time! that's why we are here for, to help each other!! no be some stuck up TECH!!!
