Panasonic Workio 2500 , dark corner when copying from the glass with ledger paper.
  • tbsoa
    • Aug 2009
    • 15
    Hi guys. Does anyone have a fix for this issue? Copying from the ADF is fine.
  • RudyNYC
    • Mar 2010
    • 13
    The heat from the fuser unit distorts the base on which the lens sit on so you have to adjust the height of the lens thru holes on top of the lens unit with a phillip screwdriver. A little turn goes a long way.
