MP 4001 SC995 ERROR
  • Stetner
    replied
    Re: MP 4001 SC995 ERROR
    It is the board mounted in the slideout rack that has the Ethernet, SD slot, memory module and HDD mounted on it.
  • Stetner
    replied
    Please excuse my ignorance lol....not sure which is which. I replaced the board that is mounted in the pullout rack that has the ethernet port on it.
    It also has the SD card slots, the memory module and HDD attached to it.
  • tnelson
    replied
    ok ... by main board do you mean the controller or the bicu?
  • Stetner
    started a topic MP 4001 SC995 ERROR
    MP 4001 SC995 ERROR
    Hi all, I have spent many hours searching for answers to this problem to no avail. I have learned this is a serial number mismatch, but I can't find how to solve it.
    Back story: This machine worked perfectly with the exception of the ethernet port. Could not get it to connect to the network. I ordered a main board on ebay to
    hopefully fix the failed ethernet port. The replacement board matches the existing one exactly, but upon powering up the machine the red dialog appears with
    SC995. It won't allow me access to much, and I can't find any info on how to solve this problem. I know it is probably is a serial # mismatch with the new controller
    board but how do I reach the screen to enter the correct information?
