RICOH copeir monthly auto meter
  • kplow1986
    • Nov 2013
    • 41
    #121
    Re: RICOH copeir monthly auto meter
    Originally posted by TonerMunkeh
    The machines can now actually do this themselves. SP5866. Set destination 1 to the email address you want to send it to, the date to 1 and the time to 12pm. Obviously GW scan to email has to be set up for this to work.
    Yes, u are right!, but only for newer model with GW. But this program can use for older model and can gather info like toner , printer status , as long as u can get Ricoh OID.
    • cesaromero
      • Nov 2011
      • 6
      #122
      Originally posted by arahael
      we're going to try it,
      In which operating system does it work?
      requirements?
      ventas.ricoh@gmail.com
      • stupidkiller
        • Oct 2011
        • 57
        #123
        hi kplow1986
        appreciate if u can send me the program
        milhyhsgnroh@hotmail.com
        • IchBin
          • Mar 2013
          • 11
          #124
          I'm also interested!
          samassefa3201@gmail.com
          Thanks!
          • luca72
            • Oct 2017
            • 1792
            #125
            hi tonermunkeh, I take this opportunity to ask something about sp 5-866 ... I tried on a 2003, I entered all the parameters following the guides of the various discussions here on the forum, only when I try with sp 5-866-112 ( test), it instantly returns "failed" the scan to mail works perfectly, you have some idea of ​​what might be missing to make it work???...
            "I'll be back"
              • 30528
              #126
              Would suggest you look into a software solution such as printtracker meter reading software that can be emailed to customer or tech installed.
              Much less wasted time service calls for meter reads or meter read problems.
              • jmhashmi
                Technical Supervisor
                • May 2009
                • 62
                #127
                I would like to have a copy.
                junaid@saudi-imaging.com
                Thanks,
                • stupidkiller
                  • Oct 2011
                  • 57
                  #128
                  im not yet get the copy
                  • Brianneoe
                    • May 2015
                    • 322
                    #129
                    Auto specified sender has to be on in the file transfer mode. SP 5866-110 set to 1 first and then power off. Power back on and then set your other settings and run a test. The key here is to power off completely before you run the test.
                    • mincopier
                      • Dec 2015
                      • 289
                      #130
                      • kplow1986
                        • Nov 2013
                        • 41
                        #131
                        I am so sorry , i am busy moving to new factory this few weeks... i will send to those who requested.... sry
                        • stupidkiller
                          • Oct 2011
                          • 57
                          #132
                          thanks thanks appreciate ^^
                          • kplow1986
                            • Nov 2013
                            • 41
                            #133
                            Hi Guys. i already sent to all of u.. pls check and provide feedback.. THX
                            • stani
                              • Jan 2013
                              • 49
                              #134
                              zhnbgt@yandex.ru
                              • Ronan Asante|
                                • Mar 2017
                                • 2
                                #135
                                Hi, info@ricopier.net, muchas gracias
