mpc5502 "replace fuser roller "
  • digicor
    • Jul 2008
    • 1153
    I have re set the fuser several times, with fuse, re set all counters, including 390*/7-***/ all that i know how to re set, even the one in 1-***
    still wants new fuser roller, Its been a while is this an NV ram issue? or is there a procedure in a certain sequence thats need to be done? i cant see having to put a new fuser in it? ive been rebuilding these units for a while, and re setting with fuse, or my little cheat fuse i made out of a thermister... Please advise Thanks
  • fbkhan3
    • May 2012
    • 421
    Re: mpc5502 "replace fuser roller "
    If you have done everything said above,just try to reset the PM or Parts counters for fuser Roller and restart.
    Hope that helps.
    Regard's
    • digicor
      • Jul 2008
      • 1153
      thank you but yes i have done all that too
      • FrohnB
        • Jul 2017
        • 1919
        What was the PM count on the fuser?
        Did you Cycle Machine after resetting counters SP 7-804-019 and 022 and 023? (Off/On).
        Omertà
        • digicor
          • Jul 2008
          • 1153
          yes i did, the pm count on the fuser is 2, its a new rebuilt fuser, all new fixing film and LFR,thermisters, ...
          i used a re set fuse, followed proceedures i use typically on these machines, never had this problem,
          any other ideas?
          • copier tech
            • 8138
            Try manual new unit set SP3902-xx & set the pressure roller from 0-1 & restart the machine.
            • digicor
              • Jul 2008
              • 1153
              i also have done this
              I think its in the NV ram.... but i dont want to think that until ive exhausted all other possibilities
              • fshead
                • 2376
                can you copy nvram from another mpc5502 and and see if that works?
                i would take an image of the existing machine before and drop it on my laptop.
                I take copies of nvrams on all my mpc3002/mpc3003 s i resell now.
                It sucks having a charge call where you just replaced over $500 WORTH of parts and cant get it to work.
                • digicor
                  • Jul 2008
                  • 1153
                  i do that too on all the '02'03's i guess the nvram is corrupt, ill re do it and c if that works
