I am doing work for a friend on his copier. It has a SC320 error code so I replaced the polygon motor but it still throws the code. I also tried to do the SC reset in the sim mode (I usually work on Sharps) but it still throws the same code. Any suggestions?
SC-320 on a Lainer LD150SP
Re: SC-320 on a Lainer LD150SP
Development roller bias leak
The development roller bias leak is detected for 60 ms after the high voltage
has been supplied to the development unit.
Development bias leak
Broken harness
Defective high voltage power supply, voltage supply
Defective high voltage supply unit -
if you've already changed the polygon engine, and controlled to have also connected the connector behind (it always hides cursed) I would try to bet on some safety switch, rare but for this, bastards ... you do not hear the turbo? .. .not with the hand above? .. usually I for convenience change all laserbox (if we have it here) with a used but clean well from me .... ps: I advise you not to try the laser engine without cover!, it could be dangerous, it could cut you like the gundam lightsaber!! ... LOL ... let us know,bye
"I'll be back"Comment
Ojar10
I think you fellas may be onto something... When I get the opportunity to go back I will take a look and update you. o7 Thank you my friends!Comment
