SC-320 on a Lainer LD150SP
  • Ojar10
    • Jun 2025
    [Error Code] SC-320 on a Lainer LD150SP
    I am doing work for a friend on his copier. It has a SC320 error code so I replaced the polygon motor but it still throws the code. I also tried to do the SC reset in the sim mode (I usually work on Sharps) but it still throws the same code. Any suggestions?
  • anothertech
    • 1762
    Re: SC-320 on a Lainer LD150SP
    Development roller bias leak
    The development roller bias leak is detected for 60 ms after the high voltage
    has been supplied to the development unit.
    􀂃 Development bias leak
    􀂃 Broken harness
    􀂃 Defective high voltage power supply, voltage supply
    􀂃 Defective high voltage supply unit
    • luca72
      • Oct 2017
      • 1758
      if you've already changed the polygon engine, and controlled to have also connected the connector behind (it always hides cursed) I would try to bet on some safety switch, rare but for this, bastards ... you do not hear the turbo? .. .not with the hand above? .. usually I for convenience change all laserbox (if we have it here) with a used but clean well from me .... ps: I advise you not to try the laser engine without cover!, it could be dangerous, it could cut you like the gundam lightsaber!! ... LOL ... let us know, bye
      "I'll be back"
      • Ojar10
        I think you fellas may be onto something... When I get the opportunity to go back I will take a look and update you. o7 Thank you my friends!
