IM C3500 jamming from all trays & bypass
  • copier tech
    • 8142
  • Coptech
    worker drone
    • 460
    Re: IM C3500 jamming from all trays & bypass
    Have not seen it but agree that it would have to be like a 24V loss that drives motors? Sensor 5V loss I would think would show a misfeed or cover open or such. Any chance they pinched a wire somewhere? Other motors controlled by same board turn in output mode?
    • GIUBOSS
      • 1427
      so the paper doesn't come out of the drawer? I had a photosensor that blocks the paper and the cable was interrupted, 1 working day to solve instead of replacing all the wiring
      • anothertech
        • 1768
        Possible bad motor? Is there another motor in the machine with the same part number you could try swapping?
        or, vertical path rollers bound up, do they turn freely?
        What is the jam code?
        • copier tech
          • 8142
          Jam code varies depending on what tray is selected.
          Jamming from ALL trays & bypass so 4x motors not driving.
          Paper it picked up, fed to the vertical path roller of each tray then jams.
          All sensors check out ok using input check.
          I suspect a failed transport IOB.
          • mikadonovan
            • May 2008
            • 2931
            Did you ever resolve this problem?
            NEVER ASSUME ANYTHING
            • copier tech
              • 8142
              Yes it was the transport motor.
              • Polarbear
                • Feb 2012
                • 1070
                Like in the registration motor?
                Press the GREEN button!!
