Aficio mp 4000
  • Sage632
    • Jul 2019
    • 45
    [CQ] Aficio mp 4000
    Hi Everyone,
    I have an unusual problem with a Ricoh mp 4000 that is stumping me.
    Copies from the table glass look passable (the client claims they are degraded, but not as bad). Copies from the doc feeder are light then dark in the middle then dark again. For instance, if I make a copy of the meter page, the right and left corners of the triangle are extremely faded. Density in the center inch of the triangle is great.
    Prints are fantastic. So my guess is something optical. I cleaned all the mirrors and the slit glass, but cannot figure out what else could be causing it.
    Thanks,
    Me
  • zed255
    How'd ya manage that?
    • 1024
    Re: Aficio mp 4000
    The supporting structure of the scanner can become bent resulting in poor CQ. Try lifting up the front left corner of the scanner while copying and see if the CQ improves. If it does you may need to 'tweak' it back up until CQ holds on it's own.
    Check the PM counters too. I have seen where a print looks good but a copy looks bad and all that was needed was a PM.
      Re: Aficio mp 4000
      after cleaning the optics, did you run adjustments? and did you clean the scanner white plate?
        • 37587
        Re: Aficio mp 4000
        Since copies from the platen glass are not showing the same problem, I would say that the DF is not setting level on the glass.
        • Sage632
          • Jul 2019
          • 45
          Re: Aficio mp 4000
          If you mean the metal plate that the paper passes over through the adf. Then yes (it was already cleaned). I could not find any automatic adjustments on the machine or or in the manual (admittedly, I did not look very hard).
          • Sage632
            • Jul 2019
            • 45
            Re: Aficio mp 4000
            I didn't think to check that... I will next time I am out there
              Re: Aficio mp 4000
              did you look in the manual for "white plate"? it is a small white strip UNDER the platen glass area... between the slit and platen glass on the scanner frame. ANY time I worked on a ricoh.. and cleaned the scanner area. Did you clean both sides of the glass?
              and yes a 'torqued adf will also play into this problem.
              • Sage632
                • Jul 2019
                • 45
                Re: Aficio mp 4000
                Ok... I think I know what ur talking about now
                No I did not.
                • Sage632
                  • Jul 2019
                  • 45
                  Re: Aficio mp 4000
                  Did not clean both sides of platen... Did clean both sides of slit glass.
                  • MIGUELMARCHENA
                    • Feb 2018
                    • 197
                    Re: Aficio mp 4000
                    saturday i happen something similar
                    clean the optics, but nothing, followed the copy but the triangle well.
                    lower the laser and clean up all etc mirrors, without removing them, eye.
                    better improvement
                    but since, lower the unit of the lens, remove the black plastic cover, and in the ccd there is a small glass, clean it, it was dirty.
                    the copy was spectacular
                    on another occasion it was the white plate that goes in the glass, it was yellow in some parts, I got white paint, paint, and voila.
                      Re: Aficio mp 4000
                      better improvement
                      Well.. he SAID HE cleaned optics... sorry didn't know I had to review the BASICS again to him.. but point made.
                      • MIGUELMARCHENA
                        • Feb 2018
                        • 197
                        Re: Aficio mp 4000
                        And in the meantime, the milkman, the mailman and the black man make fun of you
                        • anothertech
                          • 1771
                          Re: Aficio mp 4000
                          What are these adjustments you speak of?
                          • jonhiker
                            • 661
                            Re: Aficio mp 4000
                            folks have a tendancy to lean on the left corner of the df... try adjusting that corner up
                              Re: Aficio mp 4000
                              And you think I am fucking concerned? I don't give a rats ass what you or anyother puke feels/thinks about me.
                              Besides A.W. what does this have to do with the thread?
