MP7502 LCT not finishing the supply
  • digicor
    • Jul 2008
    • 1159
    THe LCT Drawer on this 7502 has stopped running the peper all the way out, it starts jamming at about a quarter inch left to go, we refill it, then it runs no problems, is there an adjustment? thats come loose, or a sensor?
    i cant seem to find any adjustment,, ive benn working on these type of machines for a long time, this is the first ive had one not go to empty
    thanks
  • Oze
    Ricoh Fanboy
    • Jul 2008
    • 1663
    Re: MP7502 LCT not finishing the supply
    Is the plate lifting evenly?
    Check the cables at the front and the rear that lift the cables...I've had them where one side lifts at different height to the other and makes the plate slightly crooked.
    • djs9164
      • Mar 2018
      • 79
      Rollers?
      • MIKON
        • Jul 2015
        • 193
        What is the jam code?
        • digicor
          • Jul 2008
          • 1159
          Originally posted by djs9164
          Rollers?
          pick up feed tires are new and the clutch as well....thanks you
          • mikadonovan
            • May 2008
            • 2931
            Might want to change the paper feed and sep rollers as well.
            NEVER ASSUME ANYTHING
            • digicor
              • Jul 2008
              • 1159
              all feed tires, sep roller are new, ive even replaced the pick up mechanism with a very new one, im having the clien keep an eye on the tray to see if its not level when this occurs again,
              • djs9164
                • Mar 2018
                • 79
                Try swapping feed units for a test.
                • MIKON
                  • Jul 2015
                  • 193
                  AGAIN
                  • digicor
                    • Jul 2008
                    • 1159
                    Originally posted by MIKON
                    AGAIN
                    Sorry, I'm not sure where to find that, I looked in sc7504, but it's just a total, please tell me where those are located, it's not in the sc section where the other codes are listed , such as " latest"
                    1,2,3,4 etc...
                    • anothertech
                      • 1771
                      1,2,3,4 etc...
                      Print the SMC report and read it.
                      • davel
                        • Oct 2011
                        • 1109
                        SP mode 5-990-4 look for jam history. Sounds like tray is not level.
