Ricoh aficio mp 4000
  • fredr
    • May 2019
    • 11
    [Dead] Ricoh aficio mp 4000
    The printer power indicator blink green then goes off, the panel is blank and machine is silent. Please help what could be the problem. The printer is ricoh aficio mp 4000
  • dalewb74
    • Feb 2018
    • 1153
    Re: Ricoh aficio mp 4000
    what have you tried to do to fix it?
    • fredr
      • May 2019
      • 11
      Iniatially it had problem with blowing varistor and fu2 then i repaired the power board now it doesn't blow fu2 but if the power is switched on the power indicator blink green then goes off and the printer is silent
      • zed255
        How'd ya manage that?
        • 1024
        Sounds like the PSU is going into over current protect. If you had bad components on the PSU board there may still be other issues not found and repaired. Try replacing the PSU.
        If you are sure the PSU is functioning correctly then you have a short or faulty component elsewhere.
        • luca72
          • Oct 2017
          • 1778
          therefore the psu has been repaired, probably there are other faults on the board, on that model in the service manual there is the PtoP tries to check the outputs, some are missing.
          "I'll be back"
          • kyoceran
            • 100
            check to see if the screen shows the outline of an SC code eg 202 or similar, a lot of the time you need to replace the laser polygon mirror motor befor repairing/replacing the board concerned, and possibly one other pcb, good luck.
            • luca72
              • Oct 2017
              • 1778
              I had told another by mistake
              "I'll be back"
              • MIKON
                • Jul 2015
                • 187
                Unplug connectors on psu one at a time to see if it recovers and narrow down the location of the problem.....
                • GIUBOSS
                  • 1435
                  This problem occurs on the MP C2800 / 3300 series. It does not seem to interest the b / w
                  • GIUBOSS
                    • 1435
                    TV or electronics service centers generally know how to repair power supply board at good prices
                    • luca72
                      • Oct 2017
                      • 1778
                      once a switch power supply is understood as a function, some faults are fairly easy to identify, the search procedure is more or less always the same, the problem is to test the pwm, or analyze signals from operational, you need the oscilloscope
                      "I'll be back"
                      • Mark Bbb
                        • Jun 2012
                        • 1662
                        could be a blocked wire, somewhere.
