mp c 3000 - Equal spaced horizontal lines when printing only
+ More Options
Posts
  • amr002eg
    • 13
    Hello all,
    i have a Mp c 3000 printing horizontal black lines equal spaced when printing.However, when I make a copy it works fine without any problem.
    attached here a sample of the printed paper.
  • GIUBOSS
    • 1437
    Re: mp c 3000 - Equal spaced horizontal lines when printing only
    try printing the page counter. Then if you're printing with ethernet cable, try USB.
    • amr002eg
      • 13
      Thanks GIUBOSS
      when printing the counter it printed fine without lines.
      the problem only occured if I print any thing from the compuetr, I tried USB & ethernet cable.
      • davel
        • Oct 2011
        • 1108
        Time for a new machine.
        • GIUBOSS
          • 1437
          Originally posted by amr002eg
          Thanks GIUBOSS
          check controller board
          • Zeldaman
            • Mar 2011
            • 946
            Hi there!
            First, i would update FW and the printerdriver.
            Greetings...
            • anothertech
              • 1771
              Does it print the lines when you print a test page directly from the print driver? What print driver are you using?
              • luca72
                • Oct 2017
                • 1791
                Hello all,
                starting from the assumption that you have tried from more than one pc, try to update the firmware and reset via sp "printer application"
                "I'll be back"
                • FrohnB
                  • Jul 2017
                  • 1919
                  Like others have said, Start with firmware.
                  Next, make sure you are using the correct MP C3000 print driver (PCL 6 or PCL 6 universal) downloaded from www.ricoh.com . Don't use the V4 drivers.
                  Could do an IMH format on HDD SP5-832-002. Maybe try a memory clear for Printer only SP 5-801-007 I believe.
                  Reseat DIMMS.
                  I'm doubting it's actually a problem with the machine. Could be something with the router (bad port), or computer in question (spooler/ memory/ etc.).
                  Omertร
                  • amr002eg
                    • 13
                    Originally posted by Zeldaman
                    Hi there!
                    Greetings...
                    could you please help me to find the firmaware and steps to update
                    • amr002eg
                      • 13
                      Hi there!
                      Greetings...
                      could you please help me to find the firmaware and steps to update, I'm using the last driver update
                      • amr002eg
                        • 13
                        it print the lines whenever I print any file, driver pl6
                        • amr002eg
                          • 13
                          Yes, I tried from different Pcs, could you please help me to find the firmaware and steps to update
                          • amr002eg
                            • 13
                            Reseat DIMMS.
                            Thanks FrohnB
                            I will trry HDD format and memor clear , I Tried also printing via usb and the lines appeared also.
                              become a CONTRIBUTOR to CTN and you can get the files you require
