MP4000 smearing issue
  • digicor
    • 1159
    When this machine wakes up the first two or three pages are not fused in the middle in the page then everything is fine and will run all day
    ive changed the fuser, same thing, upped the temp in the center , same thing
    anyone been through this?
    please advise
  • GIUBOSS
    • 1436
    Re: MP4000 smearing issue
    1- check the paper if it is damp, in this case install a heater. 2- update the firmware. 3- original toner? 4- is the fuser you installed new? if not, replace rollers and thermistors
    • sandmanmac
      • 3981
      Been through this multiple times on many of models going back several years - on other models however, and not specifically this one.
      The solution has always been to turn on Fuser Idling (SP1103-001)
      • digicor
        • 1159
        yes on all counts oem toner,new rebuilt fuser (second one) i will check the paper with the client,
        • Rezaarsenalyyyy
          • Mar 2020
          • 24
          Turn on fusing idling,increase the tempreture of heater.also in my case,it happened for me more in 110 volte matchins with trans 220 to110 when the voltage decrease.
          Sent from my Redmi 8 using Tapatalk
            • 37533
            Sandy you beat me to it.
              +2
